Notes on Birkhoff-von Neumann decomposition of doubly stochastic matrices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2016
Sur la décomposition de Birkhoff-von Neumann des matrices bistochastiques
Birkhoff-von Neumann (BvN) decomposition of doubly stochastic matrices expresses a double stochastic matrix as a convex combination of a number of permutation matrices. There are known upper and lower bounds for the number of permutation matrices that take part in the BvN decomposition of a given doubly stochastic matrix. We investigate the problem of computing a decomposition with the minimum number of permutation matrices and show that the associated decision problem is strongly NP-complete. We propose a heuristic and investigate it theoretically and experimentally.
RR-8852.pdf (756.67 Ko) Télécharger le fichier
hal-01270331 , version 1 (06-02-2016)
hal-01270331 , version 2 (08-02-2016)
hal-01270331 , version 3 (09-02-2016)
hal-01270331 , version 4 (12-02-2016)
hal-01270331 , version 5 (17-02-2016)
hal-01270331 , version 6 (23-04-2016)
  • HAL Id : hal-01270331 , version 3
Fanny Dufossé, Bora Uçar. Notes on Birkhoff-von Neumann decomposition of doubly stochastic matrices. [Research Report] RR-8852, Inria. 2016. ⟨hal-01270331v3⟩
458 Consultations
3675 Téléchargements
