On Fourier time-splitting methods for nonlinear Schrodinger equations in the semi-classical limit II. Analytic regularity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerische Mathematik Année : 2017
We consider the time discretization based on Lie-Trotter splitting, for the nonlinear Schrodinger equation, in the semi-classical limit, with initial data under the form of WKB states. We show that both the exact and the numerical solutions keep a WKB structure, on a time interval independent of the Planck constant. We prove error estimates, which show that the quadratic observables can be computed with a time step independent of the Planck constant. The functional framework is based on time-dependent analytic spaces, in order to overcome a previously encountered loss of regularity phenomenon.
splitting.pdf (272.81 Ko) Télécharger le fichier
hal-01271907 , version 1 (09-02-2016)
Rémi Carles, Clément Gallo. On Fourier time-splitting methods for nonlinear Schrodinger equations in the semi-classical limit II. Analytic regularity. Numerische Mathematik, 2017, 136 (1), pp.315-342. ⟨10.1007/s00211-016-0841-y⟩. ⟨hal-01271907⟩
151 Consultations
102 Téléchargements
