Automatic translation of FORTRAN programs to vector form, ACM Transactions on Programming Languages and Systems, vol.9, issue.4, pp.491-542, 1987. ,
DOI : 10.1145/29873.29875
Opening polyhedral compiler's black box, Proceedings of the 2016 International Symposium on Code Generation and Optimization, CGO 2016, 2016. ,
DOI : 10.1145/2854038.2854048
Code generation in the polyhedral model is easier than you think, Proceedings. 13th International Conference on Parallel Architecture and Compilation Techniques, 2004. PACT 2004., pp.7-16, 2004. ,
DOI : 10.1109/PACT.2004.1342537
URL : https://hal.archives-ouvertes.fr/hal-00017260
Contributions to High-Level Program Optimization. Habilitation Thesis, 2012. ,
Adjusting a program transformation for legality. Parallel processing letters, pp.3-17, 2005. ,
The Polyhedral Model Is More Widely Applicable Than You Think, Proceedings of the Intl. Conf. on Compiler Construction (ETAPS CC'10), pp.283-303, 2010. ,
DOI : 10.1007/978-3-642-11970-5_16
URL : https://hal.archives-ouvertes.fr/inria-00551087
A practical automatic polyhedral parallelizer and locality optimizer, Proc. of the 2008 ACM Conf. on Programming language design and implementation (PLDI'08), 2008. ,
A framework for composing highlevel loop transformations, 2008. ,
Combining Retiming and Scheduling Techniques for Loop Parallelization and Loop Tiling, Parallel Processing Letters, vol.07, issue.04, pp.379-392, 1997. ,
DOI : 10.1142/S0129626497000383
URL : https://hal.archives-ouvertes.fr/hal-00856890
SPolly: Speculative Optimizations in the Polyhedral Model, Proceedings of the 3rd International Workshop on Polyhedral Compilation Techniques, pp.55-60, 2013. ,
A Language for the Compact Representation of Multiple Program Versions, Intl. Workshop on Languages and Compilers for Parallel Computing (LCPC), pp.136-151, 2005. ,
DOI : 10.1007/978-3-540-69330-7_10
URL : https://hal.archives-ouvertes.fr/hal-00141067
Parametric integer programming, RAIRO - Operations Research, vol.22, issue.3, pp.243-268, 1988. ,
DOI : 10.1051/ro/1988220302431
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.30.9957
Array expansion, ICS, pp.429-441, 1988. ,
DOI : 10.1145/2591635.2667159
URL : https://hal.archives-ouvertes.fr/hal-01099746
Some efficient solutions to the affine scheduling problem. I. One-dimensional time, International Journal of Parallel Programming, vol.40, issue.6, pp.313-348, 1992. ,
DOI : 10.1007/BF01407835
Polyhedron model, Encyclopedia of Parallel Computing, pp.1581-1592, 2011. ,
Semi-Automatic Composition of Loop Transformations for Deep Parallelism and Memory Hierarchies, International Journal of Parallel Programming, vol.20, issue.1, pp.261-317, 2006. ,
DOI : 10.1007/s10766-006-0012-3
URL : https://hal.archives-ouvertes.fr/hal-01257288
Code generation in the polytope model, Proceedings. 1998 International Conference on Parallel Architectures and Compilation Techniques (Cat. No.98EX192), pp.106-111, 1998. ,
DOI : 10.1109/PACT.1998.727179
On index set splitting, 1999 International Conference on Parallel Architectures and Compilation Techniques (Cat. No.PR00425), pp.607-631, 2000. ,
DOI : 10.1109/PACT.1999.807572
Polly-polyhedral optimization in llvm, IMPACT 2011 First International Workshop on Polyhedral Compilation Techniques, 2011. ,
Dependence abstractions, Encyclopedia of Parallel Computing, pp.552-556, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00881133
Computing dependence direction vectors and dependence cones with linear systems, 1987. ,
A framework for unifying reordering transformations, 1993. ,
Automatic storage management for parallel programs, Parallel Computing, vol.24, issue.3-4, pp.649-671, 1998. ,
DOI : 10.1016/S0167-8191(98)00029-5
A singular loop transformation framework based on non-singular matrices, International Journal of Parallel Programming, vol.16, issue.4, pp.183-205, 1994. ,
DOI : 10.1007/BF02577874
Improving Parallelism and Data Locality with Affine Partitioning, 2001. ,
Improving data locality with loop transformations, ACM Transactions on Programming Languages and Systems, vol.18, issue.4, pp.424-453, 1996. ,
DOI : 10.1145/233561.233564
Efficient nested loop pipelining in high level synthesis using polyhedral bubble insertion, 2011 International Conference on Field-Programmable Technology, 2011. ,
DOI : 10.1109/FPT.2011.6132715
URL : https://hal.archives-ouvertes.fr/hal-00746434
Optimizing Cache Access: A Tool for Source-to-Source Transformations and Real-Life Compiler Tests, Euro-Par 2004 Parallel Processing, 10th International Euro-Par Conference, pp.72-81, 2004. ,
DOI : 10.1007/978-3-540-27866-5_10
Iterative optimization in the polyhedral model: Part II, multidimensional time, ACM SIGPLAN Conference on Programming Language Design and Implementation (PLDI'08), pp.90-100, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-01257273
Combined Iterative and Model-driven Optimization in an Automatic Parallelization Framework, 2010 ACM/IEEE International Conference for High Performance Computing, Networking, Storage and Analysis, 2010. ,
DOI : 10.1109/SC.2010.14
URL : https://hal.archives-ouvertes.fr/inria-00551067
Loop transformations: Convexity, pruning and optimization, 38th ACM SIGACT-SIGPLAN Symposium on Principles of Programming Languages (PoPL'11), pp.549-562, 2011. ,
DOI : 10.1145/1925844.1926449
URL : https://hal.archives-ouvertes.fr/inria-00551077
Generation of efficient nested loops from polyhedra, International Journal of Parallel Programming, vol.28, issue.5, pp.469-498, 2000. ,
DOI : 10.1023/A:1007554627716
A framework for enhancing data reuse via associative reordering, ACM SIGPLAN Conference on Programming Language Design and Implementation, PLDI '14, p.10, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01016093
Graphite two years after: First lessons learned from real-world polyhedral compilation, GCC Research Opportunities Workshop (GROW'10), 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00551516
Violated dependence analysis, Proceedings of the 20th annual international conference on Supercomputing , ICS '06, pp.335-344, 2006. ,
DOI : 10.1145/1183401.1183448
URL : https://hal.archives-ouvertes.fr/hal-01257290
Automatic Correction of Loop Transformations, 16th International Conference on Parallel Architecture and Compilation Techniques (PACT 2007), pp.292-304, 2007. ,
DOI : 10.1109/PACT.2007.4336220
URL : https://hal.archives-ouvertes.fr/hal-01257283
Non-affine Extensions to Polyhedral Code Generation, Proceedings of Annual IEEE/ACM International Symposium on Code Generation and Optimization, CGO '14, pp.185-194, 2014. ,
DOI : 10.1145/2581122.2544141
isl: An Integer Set Library for the Polyhedral Model, Mathematical Software -ICMS 2010, Third International Congress on Mathematical Software, pp.299-302, 2010. ,
DOI : 10.1007/978-3-642-15582-6_49
Polyhedral parallel code generation for CUDA, ACM Transactions on Architecture and Code Optimization, vol.9, issue.4, p.2013 ,
DOI : 10.1145/2400682.2400713
URL : https://hal.archives-ouvertes.fr/hal-00786677
A data locality optimizing algorithm, ACM SIGPLAN'91 Conf. on Programming Language Design and Implementation, pp.30-44, 1991. ,
Optimizing supercompilers for supercomputers, 1982. ,
Minimal data dependence abstractions for loop transformations, International Journal of Parallel Programming, vol.23, issue.4, pp.359-388, 1995. ,
DOI : 10.1007/BFb0025880
Clint: A direct manipulation tool for parallelizing compute-intensive program parts, 2014 IEEE Symposium on Visual Languages and Human-Centric Computing (VL/HCC), pp.109-112, 2014. ,
DOI : 10.1109/VLHCC.2014.6883031
URL : https://hal.archives-ouvertes.fr/hal-01055788
