Representing Legacy System Interoperability by Extending KDM - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
The complexity of software systems is continuously growing. An important part of this complexity issue concerns the interoperability between existing systems (i.e. legacy systems), where problems often occur due to heterogeneity in e.g. data, involved technologies or models. The Knowledge Discovery Metamodel (KDM) standardised by the Object Management Group (OMG) facilitates representation of existing systems, allowing them to be treated in a homogenous way at the model abstraction level. This paper defines a language suitable for modelling interoperability between these systems by extending KDM and introducing concepts that are specifically aimed at representing relevant interoperability information.
SystemInteroperabilityKDM_MMSS-ECMDAFA2008.pdf (283.39 Ko) Télécharger le fichier
hal-01272291 , version 1 (11-02-2016)
  • HAL Id : hal-01272291 , version 1
Vegard Dehlen, Frédéric Madiot, Hugo Bruneliere. Representing Legacy System Interoperability by Extending KDM. Model-driven Modernization of Software Systems Workshop (MMSS) - a ECMDA-FA 2008 Satellite Event, Jun 2008, Berlin, Germany. ⟨hal-01272291⟩
105 Consultations
105 Téléchargements
