New interface
Journal articles
Homogenization of a thermal problem with flux jump
Abstract : The goal of this paper is to analyze, through homogenization techniques, the effective thermal transfer in a periodic composite material formed by two constituents, separated by an imperfect interface where both the temperature and the flux exhibit jumps. Following the hypotheses on the flux jump, two different homogenized problems are obtained. These problems capture in various ways the influence of the jumps: in the homogenized coefficients, in the right-hand side of the homogenized problem, and in the correctors.
Document type :
Journal articles
Complete list of metadata
Cited literature [37 references]  Display  Hide  Download
https://hal.inria.fr/hal-01272936
Contributor : Renata BUNOIU Connect in order to contact the contributor
Submitted on : Friday, May 26, 2017 - 9:01:10 PM
Last modification on : Wednesday, November 3, 2021 - 4:47:06 AM
File
Bunoiu-Timofte-preprint16.pdf
Identifiers
Collections
Citation
Renata Bunoiu, Claudia Timofte. Homogenization of a thermal problem with flux jump. Networks and Heterogeneous Media, 2016, ⟨10.3934/nhm.2016009⟩. ⟨hal-01272936v2⟩
Share
Metrics
Record views
287
Files downloads
297
