A Multi-Level Framework to Identify HTTPS Services - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The development of TLS-based encrypted traffic comes with new challenges related to the management and security analysis of encrypted traffic. There is an essential need for new methods to investigate, with a proper level of identification, the increasing number of HTTPS traffic that may hold security breaches. In fact, although many approaches detect the type of an application (Web, P2P, SSH, etc.) running in secure tunnels, and others identify a couple of specific encrypted web pages through website fingerprinting, this paper proposes a robust technique to precisely identify the services run within HTTPS connections, i.e. to name the services, without relying on specific header fields that can be easily altered. We have defined dedicated features for HTTPS traffic that are used as input for a multi-level identification framework based on machine learning algorithms. Our evaluation based on real traffic shows that we can identify encrypted web services with a high accuracy.
HTTPS_identification_framework_slides.pdf (1.41 Mo) Télécharger le fichier
HTTPS_traffic_identification_framework_NOMS16.pdf (647.6 Ko) Télécharger le fichier
hal-01273160 , version 1 (30-04-2016)
Wazen M. Shbair, Thibault Cholez, Jérôme François, Isabelle Chrisment. A Multi-Level Framework to Identify HTTPS Services. IEEE/IFIP Network Operations and Management Symposium (NOMS 2016), IEEE/IFIP, Apr 2016, Istanbul, Turkey. p240-248, ⟨10.1109/NOMS.2016.7502818⟩. ⟨hal-01273160⟩
532 Consultations
1565 Téléchargements
