Optimal Control of Infinite Dimensional Bilinear Systems: Application to the Heat and Wave Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Programming Année : 2018
In this paper we consider second order optimality conditions for a bilinear optimal control problem governed by a strongly continuous semigroup operator, the control entering linearly in the cost function. We derive first and second order optimality conditions, taking advantage of the Goh transform. We then apply the results to the heat and wave equations.
ABK-partone-HAL-v2.pdf (877.51 Ko) Télécharger le fichier
hal-01273496 , version 1 (12-02-2016)
hal-01273496 , version 2 (05-09-2016)
  • HAL Id : hal-01273496 , version 2
Maria Soledad Aronna, Joseph Fréderic Bonnans, Axel Kröner. Optimal Control of Infinite Dimensional Bilinear Systems: Application to the Heat and Wave Equations. Mathematical Programming, 2018, 168 (1-2), pp.717-757. ⟨hal-01273496v2⟩
1205 Consultations
947 Téléchargements
