Programming dynamically reconfigurable open systems with SALSA, ACM SIGPLAN Notices, vol.36, issue.12, pp.20-34, 2001. ,
DOI : 10.1145/583960.583964
Concurrency Among Strangers, TGC'05: Proceedings of the 1st International Conference on Trustworthy Global Computing, pp.195-229, 2005. ,
DOI : 10.1007/11580850_12
AmbientTalk: Object-oriented Event-driven Programming in Mobile Ad hoc Networks, XXVI International Conference of the Chilean Society of Computer Science (SCCC'07), pp.3-12, 2007. ,
DOI : 10.1109/SCCC.2007.12
Kilim: Isolation-Typed Actors for Java, Proceedings of the 22nd European Conference on Object-Oriented Programming, pp.104-128, 2008. ,
DOI : 10.1007/978-3-540-70592-5_6
The actor foundry: A java-based actor programming environment, 1998. ,
The actor architecture manual, 2004. ,
Grid Computing: Software Environments and Tools, Ch. Programming, Deploying, Composing, for the Grid. URL http, 2006. ,
Asyncobjects framework, 2007. ,
Javact : a java middleware for mobile adaptive agents, 2008. ,
Aj: A systems for buildings actors with java, 2008. ,
Actors That Unify Threads and Events, Proceedings of the 9th International Conference on Coordination Models and Languages, pp.171-190, 2007. ,
DOI : 10.1007/978-3-540-72794-1_10
Why Do Scala Developers Mix the Actor Model with other Concurrency Models?, Proceedings of the 27th European conference on Object-Oriented Programming, 2013. ,
DOI : 10.1007/978-3-642-39038-8_13
Tanks, Proceedings of the 2013 workshop on Programming based on actors, agents, and decentralized control, AGERE! '13, pp.61-68, 2013. ,
DOI : 10.1145/2541329.2541331
Domains, Proceedings of the 2nd edition on Programming systems, languages and applications based on actors, agents, and decentralized control abstractions, AGERE! '12, pp.140-158, 2015. ,
DOI : 10.1145/2414639.2414644
URL : https://hal.archives-ouvertes.fr/hal-01273665
The shacl programming language, 2014. ,
A foundation for actor computation, Journal of Functional Programming, vol.7, issue.1, pp.1-72, 1997. ,
DOI : 10.1017/S095679689700261X
Designing reusable classes, Journal of Object-Oriented Programming, vol.1, issue.2, pp.22-35, 1988. ,
Parallel actor monitors: Disentangling task-level parallelism from data partitioning in the actor model, Science of Computer Programming, vol.80, 2014. ,
DOI : 10.1016/j.scico.2013.03.011
AmbientTalk: programming responsive mobile peer-to-peer applications with actors, Computer Languages, Systems & Structures, vol.40, issue.3-4 ,
DOI : 10.1016/j.cl.2014.05.002
JCoBox: Generalizing Active Objects to Concurrent Components, Proceedings of the 24th European Conference on Object-Oriented Programming, pp.275-299, 2010. ,
DOI : 10.1007/978-3-642-14107-2_13
On maintaining multiple versions in STM, Proceeding of the 29th ACM SIGACT-SIGOPS symposium on Principles of distributed computing, PODC '10, pp.16-25, 2010. ,
DOI : 10.1145/1835698.1835704
The Domain Model: Operational Semantics, Tech. rep, 2015. ,
Ribbons, ACM SIGPLAN Notices, vol.46, issue.10, pp.289-306, 2011. ,
DOI : 10.1145/2076021.2048091
Parallel Programmability and the Chapel Language, International Journal of High Performance Computing Applications, vol.21, issue.3, pp.291-312, 2007. ,
DOI : 10.1177/1094342007078442
The Fortress Language Specification, version 1.0, Tech. rep, 2008. ,
Views, Proceedings of the 32nd ACM/IEEE International Conference on Software Engineering, ICSE '10, pp.395-404, 2010. ,
DOI : 10.1145/1806799.1806858
Axum programming language, 2008. ,
Semantics-preserving sharing actors, Proceedings of the 2013 workshop on Programming based on actors, agents, and decentralized control, AGERE! '13, pp.69-80, 2013. ,
DOI : 10.1145/2541329.2541332
Inferring ownership transfer for efficient message passing, PPoPP'11: Proceedings of the 16th ACM symposium on Principles and Practice of Parallel Programming, pp.81-90, 2011. ,
Ownership-Based Isolation for Concurrent Actors on Multi-core Machines, Proceedings of the 27th European Conference on Object-Oriented Programming, pp.281-301, 2013. ,
DOI : 10.1007/978-3-642-39038-8_12
URL : https://hal.archives-ouvertes.fr/hal-00944012
The revised report on the syntactic theories of sequential control and state, Theoretical Computer Science, vol.103, issue.2, pp.235-271, 1992. ,
DOI : 10.1016/0304-3975(92)90014-7
