An Automatic Test Framework for Interactive Music Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of New Music Research Année : 2016
Un framework automatique de test pour système interactif musical
Score-Based Interactive Music Systems are involved in live performances with human musicians, reacting in realtime to audio signals and asynchronous incoming events according to a pre-specified timed scenario called mixed score. Building such a system is a difficult challenge implying strong require- ments of reliability and robustness to unforeseen errors in input. We present the application to an automatic accompaniment system of formal methods for conformance testing of critical embedded systems. Our approach is fully automatic and based on formal models constructed directly from mixed scores, specifying the behavior expected from the system when playing with musicians. It has been applied to real mixed scores and the results obtained have permitted to identify bugs in the tested system.
Antescofo_test_JNMR.pdf (581.98 Ko) Télécharger le fichier
hal-01274035 , version 1 (15-02-2016)
  • HAL Id : hal-01274035 , version 1
Florent Jacquemard, Clément Poncelet. An Automatic Test Framework for Interactive Music Systems. Journal of New Music Research, 2016, 45 (2), pp.18. ⟨hal-01274035⟩
201 Consultations
385 Téléchargements
