Structured design, IBM Systems Journal, vol.13, issue.2, pp.115-139, 1974. ,
DOI : 10.1147/sj.132.0115
Service-oriented design and development methodology, International Journal of Web Engineering and Technology, vol.2, issue.4, pp.412-442, 2006. ,
DOI : 10.1504/IJWET.2006.010423
Design Principles for B2B Services - An Evaluation of Two Alternative Service Designs, IEEE International Conference on Services Computing (SCC 2007), pp.372-379, 2007. ,
DOI : 10.1109/SCC.2007.50
Identification and Analysis of Business and Software Services—A Consolidated Approach, IEEE Transactions on Services Computing, vol.2, issue.1, pp.1-15, 2009. ,
DOI : 10.1109/TSC.2009.6
The Impact of Service Cohesion on the Analyzability of Service-Oriented Software, IEEE Transactions on Services Computing, vol.3, issue.2, pp.89-103, 2010. ,
DOI : 10.1109/TSC.2010.23
Fine-Grained Metrics of Cohesion Lack for Service Interfaces, 2011 IEEE International Conference on Web Services, pp.588-595, 2011. ,
DOI : 10.1109/ICWS.2011.27
URL : https://hal.archives-ouvertes.fr/inria-00574182
Identification of Move Method Refactoring Opportunities, IEEE Transactions on Software Engineering, vol.35, issue.3, pp.347-367, 2009. ,
DOI : 10.1109/TSE.2009.1
Metrics based refactoring, Proceedings Fifth European Conference on Software Maintenance and Reengineering, pp.30-39, 2001. ,
DOI : 10.1109/CSMR.2001.914965
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.28.9919
Decomposing object-oriented class modules using an agglomerative clustering technique, 2009 IEEE International Conference on Software Maintenance, pp.93-101, 2009. ,
DOI : 10.1109/ICSM.2009.5306332
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.157.8450
Automatic clustering of software systems using a genetic algorithm, STEP '99. Proceedings Ninth International Workshop Software Technology and Engineering Practice, pp.73-81, 1999. ,
DOI : 10.1109/STEP.1999.798481
Refactoring: Improving Coupling and Cohesion of Existing Code, Proceedings of the 11th IEEE Working Conference on Reverse Engineering (WCRE), pp.144-151, 2004. ,
Search-based determination of refactorings for improving the class structure of object-oriented systems, Proceedings of the 8th annual conference on Genetic and evolutionary computation , GECCO '06, pp.1909-1916, 2006. ,
DOI : 10.1145/1143997.1144315
Improving design quality using meta-pattern transformations: a metric-based approach, Journal of Software Maintenance and Evolution: Research and Practice, vol.16, issue.45, pp.4-5, 2004. ,
DOI : 10.1002/smr.299
Search-Based Refactoring for Software Maintenance Solving the Class Responsibility Assignment Problem in Object-Oriented Analysis with Multi-Objective Genetic Algorithms, Journal of Systems and Software IEEE Transactions on Software Engineering, vol.81, issue.36 6, pp.502-516, 2008. ,
Refactoring Object-Oriented Frameworks, 1992. ,
A survey of software refactoring, IEEE Transactions on Software Engineering, vol.30, issue.2, pp.126-139, 2004. ,
DOI : 10.1109/TSE.2004.1265817
Pareto optimal search based refactoring at the design level, Proceedings of the 9th annual conference on Genetic and evolutionary computation , GECCO '07, pp.1106-1113, 2007. ,
DOI : 10.1145/1276958.1277176
A metrics suite for object oriented design, IEEE Transactions on Software Engineering, vol.20, issue.6, pp.476-493, 1994. ,
DOI : 10.1109/32.295895
A unified framework for cohesion measurement in object-oriented systems, Proceedings Fourth International Software Metrics Symposium, pp.65-117, 1998. ,
DOI : 10.1109/METRIC.1997.637164
A Precise Method-Method Interaction-Based Cohesion Metric for Object-Oriented Classes, ACM Transactions on Software Engineering and Methodology, vol.21, issue.2, 2012. ,
DOI : 10.1145/2089116.2089118
An Information Retrieval Based Approach for Measuring Service Conceptual Cohesion, 2011 11th International Conference on Quality Software, pp.102-111 ,
DOI : 10.1109/QSIC.2011.24
Measuring ontology information by rules based transformation, Knowledge-Based Systems, vol.50, issue.0, pp.234-245, 2013. ,
DOI : 10.1016/j.knosys.2013.06.016
A quality driven Hierarchical Data Divisive Soft Clustering for information retrieval, Knowledge-Based Systems, vol.26, issue.0, pp.9-19, 2012. ,
DOI : 10.1016/j.knosys.2011.06.012
Property-based software engineering measurement, IEEE Transactions on Software Engineering, vol.22, issue.1, pp.68-86, 1996. ,
DOI : 10.1109/32.481535
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.24.25
Algorithms on Trees and Graphs, 2000. ,
DOI : 10.1007/978-3-662-04921-1
URL : http://dx.doi.org/10.1016/s0898-1221(03)80144-x
An Empirical Study on Web Service Evolution, 2011 IEEE International Conference on Web Services, pp.49-56, 2011. ,
DOI : 10.1109/ICWS.2011.114
Zarras is an assistant professor at the Univ. of Ioannina . His research interests include software architecture & design, software maintenance and middleware ,
