Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : This paper presents the sliding mode control (SMC) of unified power quality conditioners (UPQC) intended to compensate power quality issues in three-phase four-wires systems. The SMC UPQC can be applied in electrical grids or isolated grids to mitigate power quality problems at the consumer facilities and also to minimize issues for the grid supplier. The UPQC is configured as a shunt-series filter. The shunt Active Power Filter (APF) uses a three-phase rectifier with SMC to enforce sinusoidal mains currents. The series APF uses three single-phase H-bridge inverters and SMC to improve the voltage quality at the point of common coupling. SMC design, analysis and simulation results are presented and discussed.
https://hal.inria.fr/hal-01274807 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, February 16, 2016 - 11:29:16 AM Last modification on : Monday, December 13, 2021 - 4:02:02 PM Long-term archiving on: : Tuesday, May 17, 2016 - 5:25:59 PM
Nelson Santos, J. A. Silva, João Santana. Sliding Mode Control of Unified Power Quality Conditioner for 3 Phase 4 Wire Systems. 5th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Apr 2014, Costa de Caparica, Portugal. pp.443-450, ⟨10.1007/978-3-642-54734-8_49⟩. ⟨hal-01274807⟩
