Experimental Study on Induction Heating Equipment Applied in Wireless Energy Transfer for Smart Grids
This work is focused on the design of the contactless energy transmitters and testing of their electrical parameters, varying the working frequency in the kHz range. The intended application is related to the possibility to make most efficient wireless charging of different batteries from the grid, guaranteeing more acceptable use of the electric vehicles.
Informatique [cs]
