Abstract : The Cognitive Radio is a solution proposed for the increasing demand of radio spectrum. Usually cognitive radios are adopted by the non-license wireless users, which have a certain degree of cognition in order to only access to a given frequency band when the band is sensed idle. However, these bands and their use must be assessed, to avoid interfering with licensed users (primary users). The way to assess band’s occupancy is by discerning between just noise or noise plus signal. In this paper, energy-based sensing (EBS) is considered through the use of a classical energy detector. The work proposes and describes an implementation of an energy detector using a software defined radio (SDR) testbed and, after computing the probability of detection and false alarm from a real set of samples obtained with the SDR devices, we successfully validate a theoretical model for the probabilities. EBS’ performance is validated for several points of operation, i.e. for different signal-to-noise-ratio (SNR) values. These findings may be useful for building an EBS detector that defines its own decision threshold in real time given the target probabilities, since the formal probabilities are successfully validated. Moreover, our contribution also includes a detailed description of the implemented blocks using GNU Radio’s open-source software development toolkit.
https://hal.inria.fr/hal-01274819 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, February 16, 2016 - 11:33:52 AM Last modification on : Friday, February 26, 2016 - 3:36:48 PM Long-term archiving on: : Saturday, November 12, 2016 - 10:05:05 PM
Miguel Duarte, Antonio Furtado, M. Luis, Luis Bernardo, Rui Dinis, et al.. Practical Assessment of Energy-Based Sensing through Software Defined Radio Devices. Luis M. Camarinha-Matos; Nuno S. Barrento; Ricardo Mendonça. Technological Innovation for Collective Awareness Systems : 5th IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems, DoCEIS 2014, Costa de Caparica, Portugal, April 7-9, 2014. Proceedings, AICT-423, Springer, pp.525-532, 2014, IFIP Advances in Information and Communication Technology, 978-3-642-54733-1. ⟨10.1007/978-3-642-54734-8_58⟩. ⟨hal-01274819⟩
