. Cree, Cree Reaches LED Industry Milestone with 200 Lumen-Per-Watt LED, Press Releases, 2012.
I. Mila?evski, O. Tetervenoks, and I. Galkin, Assessment of Energy Efficient LED Ballasts Based on their Weight and Size, Power and Electrical Engineering, vol.29, pp.105-112, 2011.
W. Chen and S. Hui, A dimmable light-emitting diode (LED) driver with cascaded mag-amp postregulators for multistring applications, IECON 2010, 36th Annual Conference on IEEE Industrial Electronics Society, pp.1714-1724, 1722.
DOI : 10.1109/IECON.2010.5675160
C. Chen, A high accuracy current-balanced control technique for LED backlight Power Electronics Specialists Conference, IEEE, vol.4206, pp.4202-4217, 2008.
M. Schmid, D. Kuebrich, M. Weiland, and T. Duerbaum, Evaluation on the Efficiency of Power LEDs Driven with Currents Typical to Switch Mode Power Supplies, 2007 IEEE Industry Applications Annual Meeting, pp.1135-1158, 2007.
DOI : 10.1109/07IAS.2007.178
I. Milashevski, I. Galkin, and O. Tetervenok, Assessment of buck converter powered by current or voltage sources for LEDs luminary, 2012 13th Biennial Baltic Electronics Conference, pp.239-242, 2012.
DOI : 10.1109/BEC.2012.6376861
I. Galkin, O. Tetervjonok, and I. Milashevski, Comparative study of steady-state performance of voltage and current fed dimmable LED drivers, 2013 International Conference-Workshop Compatibility And Power Electronics, pp.292-297, 2013.
DOI : 10.1109/CPE.2013.6601172
I. Galkin and O. Tetervenoks, Validation of direct current control in LED lamp with non-inverting buck-boost converter, IECON 2013, 39th Annual Conference of the IEEE Industrial Electronics Society, pp.6019-6029, 2013.
DOI : 10.1109/IECON.2013.6700123
