Revisiting Roos Bias in RC4 Key Scheduling Algorithm
RC4 is one of the most popular stream cipher with wide industrial applications, it has received serious attention in cryptology literature in the last two decades. In 1995, Roos pointed out that the elements SN [y] of the permutation SN after the Key Scheduling Algorithm for the first few values of y are biased to certain combinations of secret key bytes. These correlations were theoretically studied by Paul and Maitra (SAC 2007). The formula for the correlation probabilities provided by them gives a wrong impression that the probabilities decrease as the value of y becomes larger, which is not true. In this paper, we point out some gaps in their analysis and present a detailed analysis of Roos Bias. We provide a more accurate formula for the correlation probabilities.
Cryptographie et sécurité [cs.CR]
