Abstract : In this paper, we consider symmetric disjunctive list-decoding (SLD) codes, which are a class of binary codes based on a symmetric disjunctive sum (SDS) of binary symbols. By definition, the SDS takes values from the ternary alphabet {0, 1, * }, where the symbol * denotes " erasure ". Namely: SDS is equal to 0 (1) if all its binary symbols are equal to 0 (1), otherwise SDS is equal to *. The main purpose of this work is to obtain bounds on the rate of these codes.
