Coding for T-user multiple-access channels, IEEE Transactions on Information Theory, vol.25, issue.6, pp.684-691, 1979. ,
DOI : 10.1109/TIT.1979.1056109
Algorithms for the Coin Weighing Problem with the Presence of Noise, Electronic Colloquim on Computational Complexity, p.124, 2011. ,
On two problems of information theory, Publ.Math. Inst. Hung. Acad.Sci, issue.8, pp.241-254, 1963. ,
On a combinatorial detection problem,I, Publ.Math. Inst. Hung. Acad.Sci, issue.9, pp.195-207, 1964. ,
Determining a subset from a certain combinatorial properties, Canadian J. Math, issue.18, pp.42-48, 1966. ,
On B2-sequences of vectors, Journal of Number Theory, vol.4, issue.3, pp.261-265, 1972. ,
DOI : 10.1016/0022-314X(72)90052-2
Binary B2-Sequences : A New Upper Bound, Journal of Combinatorial Theory, Series A, vol.94, issue.1, pp.152-155, 2001. ,
DOI : 10.1006/jcta.2000.3127
An improved algorithm for quantative group testing, Discrete Applied Mathematics, issue.36, pp.299-306, 1992. ,
On a coding model for a multiple-access adder channel, Problems of Information Transmission, vol.17, issue.2, pp.94-104, 1981. ,
Improved upper bound on the probability of decoding error for codes of complex structure, Problems of Information Transmission, pp.251-262, 1987. ,
Search for Sparse Active Inputs: A Review, Information Theory, Combinatorics and Search Theory, pp.609-647, 2014. ,
DOI : 10.1109/18.2636
Compressed sensing, IEEE Transactions on Information Theory, vol.52, issue.4, pp.1289-1306, 2006. ,
DOI : 10.1109/TIT.2006.871582
URL : https://hal.archives-ouvertes.fr/inria-00369486
Near-Optimal Signal Recovery From Random Projections: Universal Encoding Strategies?, IEEE Transactions on Information Theory, vol.52, issue.12, pp.5406-5425, 2006. ,
DOI : 10.1109/TIT.2006.885507
Non-Adaptive Group Testing: Explicit Bounds and Novel Algorithms, IEEE Transactions on Information Theory, vol.60, issue.5, pp.3019-3035, 2014. ,
DOI : 10.1109/TIT.2014.2310477
Generalized construction of signature code for multiple-access adder channel, 2013 IEEE International Symposium on Information Theory, pp.1655-1659, 2013. ,
DOI : 10.1109/ISIT.2013.6620508
What to do if syndromes are corrupte also, Proc. Int.Workshop Optimal Codes, 2013. ,
On error-correction under distortions in channel and syndrom, Problems of Information Transmission, p.2015 ,
The Theory of Error-Correcting Codes ,
Long Nonbinary Codes Exceeding the Gilbert???Varshamov Bound for any FixedDistance, IEEE Transactions on Information Theory, vol.50, issue.10, pp.2357-2362, 2004. ,
DOI : 10.1109/TIT.2004.834744
