Abstract : In modern telecommunication systems severe interference cased by various factors can affect the performance of the system drastically. In this case robust reception techniques are to be applied in order to mitigate the performance degradation. In this paper a single user order statistics-based receiver is considered. For the system employing the receiver in question a vector channel model and a decoder are introduced. For the proposed decoder an upper bound on the probability of incorrect decision (i.e. the probability of the fact that decoding will result in erroneous or denial decision) is given.
https://hal.inria.fr/hal-01276235
Contributor : Jean-Pierre Tillich <>
Submitted on : Friday, February 19, 2016 - 9:15:05 AM Last modification on : Tuesday, July 14, 2020 - 11:04:06 AM Long-term archiving on: : Friday, May 20, 2016 - 10:24:54 AM
Dmitry Osipov. Upper bound on the performance of an order statistics-based decoder. WCC2015 - 9th International Workshop on Coding and Cryptography 2015, Apr 2015, Paris, France. ⟨hal-01276235⟩
