Camellia: A 128-Bit Block Cipher Suitable for Multiple Platforms ??? Design andAnalysis, LNCS, vol.2012, 2000. ,
DOI : 10.1007/3-540-44983-3_4
On Multiple Linear Approximations, CRYPTO 2004, pp.1-22, 2004. ,
DOI : 10.1007/978-3-540-28628-8_1
Key Difference Invariant Bias in Block Ciphers, ASIACRYPT 2013, pp.357-376, 2013. ,
DOI : 10.1007/978-3-642-42033-7_19
Zero-Correlation Linear Cryptanalysis with FFT and Improved Attacks on ISO Standards Camellia and CLEFIA, SAC'13, 2014. ,
DOI : 10.1007/978-3-662-43414-7_16
PRESENT: An Ultra-Lightweight Block Cipher, CHES, pp.450-466, 2007. ,
DOI : 10.1007/978-3-540-74735-2_31
Integral and Multidimensional Linear Distinguishers with Correlation Zero, ASIACRYPT, pp.244-261, 2012. ,
DOI : 10.1007/978-3-642-34961-4_16
Zero Correlation Linear Cryptanalysis with Reduced Data Complexity, LNCS, vol.7549, pp.29-48, 2012. ,
DOI : 10.1007/978-3-642-34047-5_3
Scrutinizing and Improving Impossible Differential Attacks: Applications to CLEFIA, Camellia, LBlock and Simon, Palash Sarkar and Tetsu Iwata ASIACRYPT 2014, pp.179-199, 2014. ,
DOI : 10.1007/978-3-662-45611-8_10
URL : https://hal.archives-ouvertes.fr/hal-01068894
Linear Cryptanalysis of Reduced-Round PRESENT, LNCS, vol.5985, pp.302-317, 2010. ,
Multidimensional Extension of Matsui???s Algorithm 2, FSE, pp.209-227, 2009. ,
DOI : 10.1007/978-3-642-03317-9_13
Linear Cryptanalysis Method for DES Cipher, LNCS, vol.765, pp.386-397, 1993. ,
DOI : 10.1007/3-540-48285-7_33
On Probability of Success in Linear and Differential Cryptanalysis, J. Cryptology, vol.21, issue.1, pp.131-147, 2008. ,
The 128-Bit Block cipher CLEFIA (Extended Abstract), LNCS, vol.4593, pp.181-195, 2007. ,
Zero-correlation linear cryptanalysis of reduced-round LBlock, Designs, Codes and Cryptography, vol.73, issue.2, pp.683-698, 2014. ,
DOI : 10.1007/s10623-014-9976-y
General Application of FFT in Cryptanalysis and Improved Attack on CAST-256, INDOCRYPT 2014, pp.161-176, 2014. ,
DOI : 10.1007/978-3-319-13039-2_10
Related-Key Impossible Differential Attack on Reduced-Round LBlock, Journal of Computer Science and Technology, vol.7, issue.4, pp.165-176, 2014. ,
DOI : 10.1007/s11390-014-1419-8
LBlock: A Lightweight Block Cipher, ACNS, pp.327-344, 2011. ,
DOI : 10.1007/978-3-642-19574-7_16
