GBLA – Gröbner Basis Linear Algebra Package - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Brice Boyer
  • Fonction : Auteur
  • PersonId : 977005
Jean-Charles Faugère
Sylvain Lachartre
  • Fonction : Auteur
  • PersonId : 977006
Fayssal Martani
  • Fonction : Auteur
  • PersonId : 977007
This is a system paper about a new GPLv2 open source C library GBLA implementing and improving the idea [7] of Faugère and Lachartre (GB reduction). We further exploit underlying structures in matrices generated during Gröbner basis computations in algorithms like F4 or F5 taking advantage of block patterns by using a special data structure called multilines. Moreover, we discuss a new order of operations for the reduction process. In various different experimental results we show that GBLA performs better than GB reduction or Magma in sequential computations (up to 40% faster) and scales much better than GB reduction for a higher number of cores: On 32 cores we reach a scaling of up to 26. GBLA is up to 7 times faster than GB reduction. Further, we compare different parallel schedulers GBLA can be used with. We also developed a new advanced storage format that exploits the fact that our matrices are coming from Gröbner basis computations, shrinking storage by a factor of up to 4. A huge database of our matrices is freely available with GBLA.
groblin.pdf (2.05 Mo) Télécharger le fichier
hal-01276346 , version 1 (19-02-2016)
hal-01276346 , version 2 (22-11-2016)
Brice Boyer, Christian Eder, Jean-Charles Faugère, Sylvain Lachartre, Fayssal Martani. GBLA – Gröbner Basis Linear Algebra Package. 41st International Symposium on Symbolic and Algebraic Computation, Jul 2016, Waterloo, ON, Canada. pp.135-142, ⟨10.1145/2930889.2930914⟩. ⟨hal-01276346v2⟩
914 Consultations
469 Téléchargements
