GBLA – Gröbner Basis Linear Algebra Package
This is a system paper about a new GPLv2 open source C library GBLA implementing and improving the idea of Faug\`ere and Lachartre (GB reduction). We further exploit underlying structures in matrices generated during Gröbner basis computations in algorithms like F4 or F5 taking advantage of block patterns by using a special data structure called multilines. Moreover , we discuss a new order of operations for the reduction process. In various different experimental results we show that GBLA performs better than GB reduction or Magma in sequential computations (up to 40% faster) and scales much better than GB reduction for a higher number of cores: On 32 cores we reach a scaling of up to 26. GBLA is up to 7 times faster than GB
groblin-arxiv.pdf (1.05 Mo)
Télécharger le fichier
orig-mat.pdf (886.79 Ko)
