Delaunay triangulations on orientable surfaces of low genus
Earlier work on Delaunay triangulation of point sets on the 2D flat torus, which is locally
isometric to the Euclidean plane, was based on lifting the point set to a locally isometric 9-sheeted
covering space of the torus.
Under mild conditions the Delaunay triangulation of the lifted point set, consisting of 9 copies
of the input set, projects to the Delaunay triangulation of the input set.
We improve and generalize this work. First we present a new
construction based on an 8-sheeted covering space, which shows that
eight copies suffice for the standard flat torus.
Then we generalize this construction to the context of compact orientable surfaces of higher
genus, which are locally isometric to the hyperbolic plane.
We investigate more thoroughly the Bolza surface, homeomorphic to a sphere with two handles,
both because it is the hyperbolic surface with lowest genus,
and because triangulations on the Bolza surface have applications in
various fields such as neuromathematics and cosmological models.
While the general properties (existence results of appropriate covering spaces)
show similarities with the results for the flat case, explicit constructions and their proofs are much
more complex, even in the case of the apparently simple Bolza surface.
One of the main reasons is the fact that two hyperbolic translations do not commute in general.
To the best of our knowledge, the results in this paper are the first ones of this kind.
The interest of our contribution lies not only in the results, but
most of all in the construction of covering spaces itself and the study of their properties.
paper20.pdf (1.17 Mo)
Télécharger le fichier
triangles-238.pdf (23.32 Ko)
Format : Figure, Image
