Qualitative Symbolic Perturbation
In a classical Symbolic Perturbation scheme, degeneracies are handled by substituting some polynomials in ε for the inputs of a predicate. Instead of a single perturbation, we propose to use a sequence of (simpler) perturbations. Moreover, we look at their effects geometrically instead of algebraically; this allows us to tackle cases that were not tractable with the classical algebraic approach.
Géométrie algorithmique [cs.CG]
socg16-33.pdf (715.04 Ko)
Télécharger le fichier
Format : Figure, Image
