A new constellation for space-time coding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we propose a new encoding scheme for space-time coding. This encoding relies on the generalisation [2] of Gabidulin codes to innite elds. This enables to make use of the properties of Gabidulin codes, namely, we can use algebraic decoding algorithms.
wcc15-th3-2.pdf (351.48 Ko) Télécharger le fichier
hal-01276475 , version 1 (19-02-2016)
  • HAL Id : hal-01276475 , version 1
Gwezheneg Robert. A new constellation for space-time coding. WCC 2015 - Proceedings of the 9th International Workshop on Coding and Cryptography, Anne Canteaut, Gaëtan Leurent, Maria Naya-Plasencia, Apr 2015, Paris, France. ⟨hal-01276475⟩
209 Consultations
82 Téléchargements
