Bounds on the number of rational points of algebraic hypersurfaces over finite fields, with applications to projective Reed-Muller codes, Advances in Mathematics of Communications, vol.10, issue.2 ,
DOI : 10.3934/amc.2016010
On plane arcs contained in cubic curves, Finite Fields and Their Applications, pp.69-90, 2002. ,
Projective Geometries Over Finite Fields, Oxford Mathematical Monographs, 1998. ,
The parameters of projective Reed???M??ller codes, Discrete Mathematics, vol.81, issue.2, pp.81-217, 1990. ,
DOI : 10.1016/0012-365X(90)90155-B
Les Arrangements Minimaux et Maximaux d'Hyperplans dans P n (Fq), C. R. Acad. Sc. Paris, Ser. I, pp.344-287, 2007. ,
DOI : 10.1016/j.crma.2007.01.006
The second weight of generalized Reed-Muller codes in most cases, Cryptography and Communications, pp.19-40, 2010. ,
DOI : 10.1007/s12095-009-0014-2
URL : https://hal.archives-ouvertes.fr/hal-01079448
Second highest number of points of hypersurfaces in F n q , Finite Fields and their Applications, pp.444-449, 2007. ,
Special numbers of rational points on hypersurfaces in the <mml:math altimg="si1.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mi>n</mml:mi></mml:math>-dimensional projective space over a finite field, Discrete Mathematics, vol.309, issue.16, pp.5048-5059, 2009. ,
DOI : 10.1016/j.disc.2009.03.021
Nonsingular plane cubic curves over finite fields, Journal of Combinatorial Theory, Series A, vol.46, issue.2, pp.183-211, 1987. ,
DOI : 10.1016/0097-3165(87)90003-3
URL : http://doi.org/10.1016/0097-3165(87)90003-3
Projective Reed-Muller codes, IEEE Transactions on Information Theory, vol.37, issue.6, pp.1567-1576, 1991. ,
DOI : 10.1109/18.104317
On the number of rational points on codimension-1 algebraic sets in Pn(Fq), Discrete Mathematics, pp.321-334, 1994. ,
DOI : 10.1016/0012-365X(93)E0009-S
Abelian Varieties over Finite Fields, Annales Scientifiques de l' ´ Ecole Normale Supérieure, pp.521-560, 1969. ,
