Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : KD2R allows the automatic discovery of composite key constraints in RDF data sources that conform to a given ontol-ogy. We consider data sources for which the Unique Name Assumption is fulfilled. KD2R allows this discovery without having to scan all the data. Indeed, the proposed system looks for maximal non keys and derives minimal keys from this set of non keys. KD2R has been tested on several datasets available on the web of data and it has obtained promising results when the discovered keys are used to link data. In the demo, we will demonstrate the functionality of our tool and we will show on several datasets that the keys can be used in a datalinking tool.
https://hal.inria.fr/hal-01276594 Contributor : Fatiha SaïsConnect in order to contact the contributor Submitted on : Friday, February 19, 2016 - 4:18:49 PM Last modification on : Sunday, June 26, 2022 - 12:05:13 PM Long-term archiving on: : Saturday, November 12, 2016 - 11:30:16 PM
Danai Symeonidou, Nathalie Pernelle, Fatiha Saïs. Discovering keys in RDF/OWL dataset with KD2R. In the proceedings of the 2nd International workshop on Open Data (WOD 2013), Jun 2013, Paris, France. ⟨10.1145/2500410.2500419⟩. ⟨hal-01276594⟩
