ISOGEOMETRIC ANALYSIS: APPROXIMATION, STABILITY AND ERROR ESTIMATES FOR h-REFINED MESHES, Mathematical Models and Methods in Applied Sciences, vol.16, issue.07, pp.1031-1090, 2006. ,
DOI : 10.1142/S0218202506001455
Isogeometric Analysis and error estimates for high order partial differential equations in fluid dynamics Computers & Fluids, pp.277-303, 2014. ,
Analysis-aware modeling: Understanding quality considerations in modeling for isogeometric analysis, Computer Methods in Applied Mechanics and Engineering, vol.199, issue.5-8, pp.334-356, 2010. ,
DOI : 10.1016/j.cma.2009.09.010
Constructing analysis-suitable parameterization of computational domain from CAD boundary by variational harmonic method, Journal of Computational Physics, vol.252, pp.275-289, 2013. ,
DOI : 10.1016/j.jcp.2013.06.029
URL : https://hal.archives-ouvertes.fr/inria-00585663
Parameterization of computational domain in isogeometric analysis: Methods and comparison, Computer Methods in Applied Mechanics and Engineering, vol.200, issue.23-24, pp.2021-2031, 2011. ,
DOI : 10.1016/j.cma.2011.03.005
Circular element: Isogeometric elements of smooth boundary, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.30-32, pp.2391-2402, 2009. ,
DOI : 10.1016/j.cma.2009.02.029
Hermite type spline spaces over rectangular meshes with arbitrary topology accepted by Communications in Computational Physics, 2016. ,
Existence of stiffness matrix integrals for singularly parameterized domains in isogeometric analysis, Computer Methods in Applied Mechanics and Engineering, vol.200, issue.49-52, pp.3568-3582, 2011. ,
DOI : 10.1016/j.cma.2011.08.023
<mml:math altimg="si27.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mrow><mml:msup><mml:mrow><mml:mi>H</mml:mi></mml:mrow><mml:mrow><mml:mn>2</mml:mn></mml:mrow></mml:msup></mml:mrow></mml:math> regularity properties of singular parameterizations in isogeometric analysis, Graphical Models, vol.74, issue.6, pp.361-372, 2012. ,
DOI : 10.1016/j.gmod.2012.05.006
Approximation properties of isogeometric function spaces on singularly parameterized domains preprint ,
Construction of smooth isogeometric function spaces on singularly parameterized domains. Curves and Surfaces 2014, LNCS, vol.9213, pp.433-451, 2015. ,
Mapping techniques for isogeometric analysis of elliptic boundary value problems containing singularities, Computer Methods in Applied Mechanics and Engineering, vol.254, pp.334-352, 2013. ,
DOI : 10.1016/j.cma.2012.09.009
Enriched isogeometric analysis of elliptic boundary value problems in domains with cracks and/or corners, International Journal for Numerical Methods in Engineering, vol.20, issue.5-8, pp.149-180, 2014. ,
DOI : 10.1002/nme.4580
An Analysis of the Finite-Element Method, Journal of Applied Mechanics, vol.41, issue.1, 1973. ,
DOI : 10.1115/1.3423272
Dimensions of spline spaces over T-meshes, Journal of Computational and Applied Mathematics, vol.194, issue.2, pp.267-283, 2006. ,
DOI : 10.1016/j.cam.2005.07.009
A multivariate faa di bruno formula with applications Transactions of the, pp.503-520, 1996. ,
Superelements for the finite element solution of twodimensional elliptic problems with boundary singularities Finite Elements in Analysis and Design, pp.315-335, 1997. ,
General lagrange and hermit interpolation in R n with applications to finite element methods, Archive for Rational Mechanics and Analysis, pp.177-199, 1972. ,
H1-parameterizations of planar physical domains with complex topology in isogeometric analysis., preprint, https, 2015. ,
