Partitioning and Dynamic Load Balancing for the Numerical Solution of Partial Differential Equations, Numerical Solution of Partial Differential Equations on Parallel Computers, pp.55-88, 2006. ,
DOI : 10.1007/3-540-31619-1_2
Hypergraph partitioning for VLSI CAD, Proceedings of the 36th ACM/IEEE conference on Design automation conference , DAC '99, pp.349-354, 1999. ,
DOI : 10.1145/309847.309955
Clustering spatial networks for aggregate query processing: A hypergraph approach, Information Systems, vol.33, issue.1, pp.1-17, 2008. ,
DOI : 10.1016/j.is.2007.04.001
Dynamic load balancing in computational mechanics, Computer Methods in Applied Mechanics and Engineering, vol.184, issue.2-4, pp.485-500, 2000. ,
DOI : 10.1016/S0045-7825(99)00241-8
Adaptive decomposition and remapping algorithms for object-space-parallel direct volume rendering of unstructured grids, Journal of Parallel and Distributed Computing, vol.67, issue.1, pp.77-99, 2007. ,
DOI : 10.1016/j.jpdc.2006.05.005
A repartitioning hypergraph model for dynamic load balancing, Journal of Parallel and Distributed Computing, vol.69, issue.8, pp.711-724, 2009. ,
DOI : 10.1016/j.jpdc.2009.04.011
Multi-level direct K-way hypergraph partitioning with multiple constraints and fixed vertices, Journal of Parallel and Distributed Computing, vol.68, issue.5, pp.609-625, 2008. ,
DOI : 10.1016/j.jpdc.2007.09.006
URL : https://hal.archives-ouvertes.fr/hal-00803479
Graph partitioning models for parallel computing, Parallel Computing, vol.26, issue.12, pp.1519-1534, 2000. ,
DOI : 10.1016/S0167-8191(00)00048-X
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.130.5005
Computers and Intractibility: A Guide to the Theory of NP-Completeness, 1979. ,
An improved spectral graph partitioning algorithm for mapping parallel computations, SIAM J. Sci. Comput, vol.16, issue.2, 1995. ,
A multilevel algorithm for partitioning graphs, 1995 ACM/IEEE conference on Supercomputing, 1995. ,
Parallel multilevel k-way partitioning scheme for irregular graphs, Proceedings of the 1996 ACM/IEEE conference on Supercomputing (CDROM) , Supercomputing '96, pp.96-129, 1998. ,
DOI : 10.1145/369028.369103
An Efficient Heuristic Procedure for Partitioning Graphs, Bell System Technical Journal, vol.49, issue.2, pp.291-307, 1970. ,
DOI : 10.1002/j.1538-7305.1970.tb01770.x
A linear-time heuristic for improving network partitions, 19th Design Automation Conference, pp.175-181, 1982. ,
Think Locally, Act Globally: Highly Balanced Graph Partitioning, Proceedings of the 12th International Symposium on Experimental Algorithms (SEA'13), ser. LNCS, pp.164-175, 2013. ,
DOI : 10.1007/978-3-642-38527-8_16
URL : http://algo2.iti.kit.edu/documents/kahip/highly_balanced.pdf
PaToH: A Multilevel Hypergraph Partitioning Tool Zoltan: Parallel partitioning, load balancing and data-management services, 1999. ,
On the validity of a front-oriented approach to partitioning large sparse graphs with a connectivity constraint, Numerical Algorithms, vol.2, issue.1, pp.193-214, 1996. ,
DOI : 10.1007/BF02141748
Differential greedy for the 0-1 equicut problem, Proceedings of the DIMACS Workshop on Network Design: Connectivity and Facilities Location, pp.3-21, 1997. ,
Greedy algorithms for k-way graph partitioning, the 6th international conference on advanced computing, 1998. ,
Shape-optimized mesh partitioning and load balancing for parallel adaptive FEM, Parallel Computing, vol.26, issue.12, pp.1555-1581, 2000. ,
DOI : 10.1016/S0167-8191(00)00043-0
Benchmarking for graph clustering and partitioning, " in Encyclopedia of Social Network Analysis and Mining, pp.73-82, 2014. ,
Coupling-aware graph partitioning algorithms: Preliminary study, 2014 21st International Conference on High Performance Computing (HiPC), pp.1-10, 2014. ,
DOI : 10.1109/HiPC.2014.7116879
URL : https://hal.archives-ouvertes.fr/hal-01069578
