On the eigenfunctions and on the eigenvalues of general elliptic boundary value problems, Communications on Pure and Applied Mathematics, vol.12, issue.2, pp.119-147, 1962. ,
DOI : 10.1002/cpa.3160150203
Sur l'équation générale ut = a(., u, ?(., u)x)x dans L 1 , II, Etude du problème d'évolution, Ann. Inst. Henri Poincaré, vol.12, pp.6-727, 1995. ,
Regulation of an irrigation canal system through the semigroup approach, Proceedings of the International Workshop Regulation of Irrigation Canals : Sates of the Art of Research and Applications, pp.261-276, 1997. ,
Integrale de Lebesgue, mesure et integration; Cépadues-Editions, 1996. ,
Opérateurs maximaux monotones et semi-groupes de contractions dans les espaces de Hilbert, 1973. ,
Analyse fonctionnelle: théorie et applications, 1983. ,
Asymptotic behavior for solutions of a one-dimensional parabolic equation with homogeneous Neumann boundary conditions, Journal of Differential Equations, vol.18, issue.1, pp.111-134, 1975. ,
DOI : 10.1016/0022-0396(75)90084-4
On the Null Asymptotic Stabilization of the Two-Dimensional Incompressible Euler Equations in a Simply Connected Domain, SIAM Journal on Control and Optimization, vol.37, issue.6, pp.1874-1896, 1999. ,
DOI : 10.1137/S036301299834140X
Partial differential equations, 1998. ,
Partial differential equations of parabolic type, Prentice-Hall, 1963. D. Gilbarg, N. Trudinger, Elliptic partial differential equations of second order, 1977. ,
Characteristic conditions for exponential stability of linear dynamical systems in Hilbert spaces, Ann. Diff. Eqns, vol.1, pp.45-53, 1985. ,
Exact controllability and stabilization: the multiplier method, 1994. ,
Linear and quasilinear elliptic equations, 1968. ,
Linear and quasilinear equations of parabolic type, Amer. Math. society, 1968. ,
Le génie chimique à l'usage des chimistes, Lavoisier TEC & DOC, 1998. ,
Bases mathématiques de la théorie des systèmes asservis non linéaires, Analyse Appliquée et Informatique, 1976. ,
Asymptotic behaviour and stability of solutions of semilinear diffusion equations, Publ, pp.401-454, 1979. ,
Convergence of solutions of one-dimensional semilinear parabolic equations, Journal of Mathematics of Kyoto University, vol.18, issue.2, pp.221-227, 1978. ,
DOI : 10.1215/kjm/1250522572
Limiting cases and approximate solutions for a fixedbed reactors with periodic flow reversal, 1995. ,
Semigroups of Linear Operators and Applications to Partial Differential Equations, 1983. ,
DOI : 10.1007/978-1-4612-5561-1
Maximum principles in differential equations, 1984. ,
DOI : 10.1007/978-1-4612-5282-5
Exponential Decay of Solutions to Hyperbolic Equations in Bounded Domains, Indiana University Mathematics Journal, vol.24, issue.1, pp.79-86, 1974. ,
DOI : 10.1512/iumj.1975.24.24004
On the linear stability of hyperbolic PDEs and viscoelastic flows, ZAMP Zeitschrift f???r angewandte Mathematik und Physik, vol.23, issue.6, pp.854-865, 1994. ,
DOI : 10.1007/BF00952081
A Lyapunov functional and long-time behaviour for a degenerate parabolic problem, Advances in Mathematical sciences and applications, pp.243-266, 1996. ,
Étude de la stabilité asymptotique de quelques modèles de transfert de chaleur, Thèse doctorale, 141 pages, 2004. ,
Exponential stability of symmetric hyperbolic systems using Lyapunov functionals, to appear in the Proceedings of Methods and Models in Automation and Robotics, 2004. ,
Etude des équations générales ut ? ?(u)xx + f (u)x = v par la théorie des semi-groupes non linéaires dans L 1, Thèse de 3 eme cycle, 1982. ,
Equivalence of one- and two-phase models for heat transfer processes in packed beds: one dimensional theory, Chemical Engineering Science, vol.29, issue.2, pp.485-491, 1974. ,
DOI : 10.1016/0009-2509(74)80059-X
Commande des systèmes à paramètres distribués, Mémoire de l'Habilitation à Diriger la Recherche, 1997. ,
Exponential stability and transfer functions of processes governed by symmetric hyperbolic systems, ESAIM : Control, Optimization and Calculus of Variations, pp.421-442, 2002. ,
Proportional and integral regulation of irrigation canal systems governed by the St Venant equation, The proceedings of the IFAC world congress, pp.147-152, 1999. ,
Analyse et commande d'un échangeur thermique à contre-courant, pp.377-396, 1991. ,
