Stable determination of corrosion by a single electrostatic measurement, Inverse Problems, pp.973-984, 2003. ,
Detection of nonlinear corrosion by electrostatic measurements, Applicable Analysis, vol.85, pp.107-128, 2006. ,
Solving elliptic Cauchy problems and the identification of nonlinear corrosion, Journal of Computational and Applied Mathematics, vol.198, pp.307-320, 2007. ,
Data completion via an energy error functional, C. R. Acad. Sci. Paris Mécanique, pp.171-177, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00086964
Hardy approximation to L p functions on subsets of the circle avec 1 ? p < ?, Constructive Approximation, pp.41-56, 1998. ,
Reinforcement by a thin layer with oscillating thickness, App. Math. Opt, vol.16, pp.247-261, 1988. ,
A stable recovery method for the Robin inverse problem, Mat. and Comp. in Simul, pp.367-383, 2004. ,
Error estimates in smoothing noisy data using cubic B-Splines, C.R. Acad. Sci. Paris, Série I, vol.346, pp.107-112, 2008. ,
Logarithmic stability estimates for a Robin coefficient in 2D Laplace inverse problems, Inverse Problems, pp.47-59, 2004. ,
Parameter identification for Laplace equation and approximation in Hardy classes, J. Inv. Ill. P. Problems, vol.11, pp.33-57, 2003. ,
Solution of the Cauchy problem using iterated Tikhonov regularization, Inverse Problems, pp.553-570, 2001. ,
Stability of the solutions of an inverse problem for Laplace's equation in a thin strip, Numer. Funct. Anal. and Optimiz, vol.22, pp.549-560, 2001. ,
Robust numerical algorithms based on analytic approximation for the solution of inverse problems in annular domains ,
Nondestructive evaluation of corrosion damage using electrostatic measurements, pp.127-136, 1995. ,
A computational quasi-reversibility method for Cauchy problems for Laplace's equation, in SIAM J. Appl. Math, vol.51, pp.1653-1675, 1995. ,
Determining conductivity by boundary measurements, interior results, Comm. Pure Appl. Math, vol.38, pp.644-667, 1985. ,
Relaxation of a variational method for impedance computed tomography, Comm. Pure Appl. Math, vol.40, pp.745-777, 1987. ,
An iterative method for solving the Cauchy problem for elliptic equations, Comput. Math. Phys, vol.31, pp.45-52, 1991. ,
Analytic extensions and Cauchy-type inverse problems on annular domains: stability results, J. Inv. Ill. P. Problems, vol.16, pp.189-204, 2006. ,
An effective nonlinear boundary condition for a corroding surface. identification of the damage based on steady state electric data, Zeitschrift fur Angewandte Mathematik und Physik, pp.656-679, 1998. ,
Determination of the convective transfer coefficient in elliptic problems from a nonstandard boundary condition Simulation, modelling, and numerical analysis, pp.13-20, 2000. ,
A numerical approach for the determination of a missing boundary data in elliptic problems, Appl. Math. and Comp, vol.147, pp.569-580, 2004. ,
