Effective criteria for bigraded birational maps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2017
In this paper, we consider rational maps whose source is a product of two subvarieties, each one being embedded in a projective space. Our main objective is to investigate birationality criteria for such maps. First, a general criterion is given in terms of the rank of a couple of matrices that became to be known as Jacobian dual matrices. Then, we focus on rational maps from the product of two projectine lines to the projective plane in very low bidegrees and provide new matrix-based birationality criteria by analyzing the syzygies of the defining equations of the map, in particular by looking at the dimension of certain bigraded parts of the syzygy module. Finally, applications of our results to the context of geometric modeling are discussed at the end of the paper.
BigradedCremona-preprint.pdf (557.53 Ko) Télécharger le fichier
hal-01278405 , version 1 (24-02-2016)
Nicolás Botbol, Laurent Busé, Marc Chardin, Seyed Hamid Hassanzadeh, Aron Simis, et al.. Effective criteria for bigraded birational maps. Journal of Symbolic Computation, 2017, 81, pp.69-87. ⟨10.1016/j.jsc.2016.12.001⟩. ⟨hal-01278405⟩
589 Consultations
243 Téléchargements
