Two Short Presentations related to Cancer Modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Revue Africaine de Recherche en Informatique et Mathématiques Appliquées Année : 2009
This paper contains two short presentations related to the mathematical modeling of Cancer. The first part intends to introduce a tumour-immune system interaction, which describes the early dynamics of cancerous cells, competing with the immune system, potentially leading to either the elimination of tumoral cells or to the viability of a solid tumor. The second part of the paper addresses the case where a solid tumor has grown enough to initiate angiogenesis, a process which equips the tumor with its own blood network. Nash game theory is used to model the interaction between activators and inhibitors of the angiogenesis process.
arima0901.pdf (227.28 Ko) Télécharger le fichier
hal-01278770 , version 1 (24-02-2016)
A. Habbal, P.-E. Jabin. Two Short Presentations related to Cancer Modeling. Revue Africaine de Recherche en Informatique et Mathématiques Appliquées, 2009, Volume 10, 2008 - 2009, pp.19-28. ⟨10.46298/arima.1919⟩. ⟨hal-01278770⟩
113 Consultations
1086 Téléchargements
