Journal articles
Simulation du remplissage des moules par la méthode des éléments Finis / volume contrôle dans les procédés RTM
J. Samir 1 M. Hattabi 1 J. Echaabi 1 A. Saouab 2 C.H. Park 2
1 ENSEM - Equipe de Recherche Appliqué sur les polymères
ENSEM - Ecole Nationale Supérieure d'Electricité et de Mécanique [Casablanca], UH2MC - Université Hassan II [Casablanca]
Abstract : In the course of this study, the simulation of the resin flow in the RTM process is developed by the control volume finite element method (CVFEM) coupled with the equation of the free surface location. This location is made by means of the so called "Volume of Fluid" methods or VOF. Thus, the position of the flow front, the time-lapse and the rate of the non saturated zone are calculated at every step. Our results will be compared with the experimental and analytical models in the literature. On the whole, our study is concerned with the simulation of the thermally insulated filling of moulds in RTM process while adopting the CVFEM and VOF method, taking into account the presence of obstacles, coupled with the thickness variation effect and the reinforcement coats.
Document type :
Journal articles
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/hal-01278771
Contributor : Coordination Episciences Iam Connect in order to contact the contributor
Submitted on : Wednesday, February 24, 2016 - 5:43:15 PM
Last modification on : Tuesday, October 19, 2021 - 5:34:16 PM
Long-term archiving on: : Wednesday, May 25, 2016 - 10:41:00 AM
File
arima0808.pdf
Publisher files allowed on an open archive
Identifiers
Collections
Citation
J. Samir, M. Hattabi, J. Echaabi, A. Saouab, C.H. Park. Simulation du remplissage des moules par la méthode des éléments Finis / volume contrôle dans les procédés RTM. Revue Africaine de la Recherche en Informatique et Mathématiques Appliquées, INRIA, 2008, Volume 10, 2008 - 2009, pp.1-15. ⟨10.46298/arima.1918⟩. ⟨hal-01278771⟩
Share
Metrics
Record views
103
Files downloads
1196
