A new nonconvex variational approach for sensory neurons receptive field estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2016
Determining the receptive field of a visual sensory neuron is crucial to characterize the region of the visual field and the stimuli this neuron is sensitive to. We propose a new method to estimate receptive fields by a nonconvex variational approach, thus relaxing the simplifying and unrealistic assumption of convexity made by standard approaches. The method consists in studying a relaxed discrete energy minimized by a proximal alternating minimization algorithm. We compare our approach with the classical spike-triggered-average technique on simulated data, considering a typical retinal ganglion cell as ground truth. Results show a high improvement in term of accuracy and convergence with respect to the duration of the experiment.
RR-8837.pdf (1.15 Mo) Télécharger le fichier
hal-01279999 , version 1 (28-02-2016)
hal-01279999 , version 2 (10-05-2016)
hal-01279999 , version 3 (31-08-2016)
  • HAL Id : hal-01279999 , version 1
Audric Drogoul, Gilles Aubert, Bruno Cessac, Pierre Kornprobst. A new nonconvex variational approach for sensory neurons receptive field estimation. [Research Report] 8837, Inria Sophia Antipolis. 2016, pp.7. ⟨hal-01279999v1⟩
439 Consultations
200 Téléchargements
