Proximal Alternating Minimization and Projection Methods for Nonconvex Problems: An Approach Based on the Kurdyka-??ojasiewicz Inequality, Mathematics of Operations Research, vol.35, issue.2, pp.438-457, 2010. ,
DOI : 10.1287/moor.1100.0449
Fast Gradient-Based Algorithms for Constrained Total Variation Image Denoising and Deblurring Problems, IEEE Transactions on Image Processing, vol.18, issue.11, pp.2419-2434, 2009. ,
DOI : 10.1109/TIP.2009.2028250
A l1-unified variational framework for image restoration, Proceedings of the 8th European Conference on Computer Vision, pp.1-13, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00217251
Real algebraic and semi-algebraic sets. Actualités mathématiques. Hermann, 1990. ,
Active pixel sensor array for high spatio-temporal resolution electrophysiological recordings from single cell to large scale neuronal networks, Lab on a Chip, vol.3, issue.18, pp.92644-2651, 2009. ,
DOI : 10.1002/acs.1077
A Second-Order Model for Image Denoising. Set-Valued and Variational Analysis, pp.277-306, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00440872
The ??ojasiewicz Inequality for Nonsmooth Subanalytic Functions with Applications to Subgradient Dynamical Systems, SIAM Journal on Optimization, vol.17, issue.4, pp.1205-1223, 2007. ,
DOI : 10.1137/050644641
Clarke Subgradients of Stratifiable Functions, SIAM Journal on Optimization, vol.18, issue.2, pp.556-572, 2007. ,
DOI : 10.1137/060670080
Distributed Optimization and Statistical Learning via the Alternating Direction Method of Multipliers, Machine Learning, pp.1-122, 2010. ,
DOI : 10.1561/2200000016
Functional Analysis, Sobolev Spaces and Partial Differential Equations. Universitext, 2010. ,
Temporal Precision in the Visual Pathway through the Interplay of Excitation and Stimulus-Driven Suppression, Journal of Neuroscience, vol.31, issue.31, pp.3111313-11327, 2011. ,
DOI : 10.1523/JNEUROSCI.0434-11.2011
Enhancing Sparsity by Reweighted ??? 1 Minimization, Journal of Fourier Analysis and Applications, vol.7, issue.3, pp.5-6877, 2008. ,
DOI : 10.1007/s00041-008-9045-x
Do We Know What the Early Visual System Does?, Journal of Neuroscience, vol.25, issue.46, pp.2510577-10597, 2005. ,
DOI : 10.1523/JNEUROSCI.3726-05.2005
An Algorithm for Total Variation Minimization and Applications, J. Math. Imaging Vis, vol.20, issue.12, pp.89-97, 2004. ,
A simple white noise analysis of neuronal light responses, Network: Computation in Neural Systems, vol.12, issue.2, pp.199-213, 2001. ,
DOI : 10.1080/713663221
Proximal Splitting Methods in Signal Processing, Fixed-Point Algorithms for Inverse Problems in Science and Engineering, pp.185-212, 2011. ,
DOI : 10.1007/978-1-4419-9569-8_10
URL : https://hal.archives-ouvertes.fr/hal-00643807
Tame topology and o-minimal structures. Number 248 in London Mathematical Society lecture note series, p.550530719, 2003. ,
Analyse convexe et problèmes variationnels, Etudes mathématiques . Dunod, 1974. ,
The contrast sensitivity of retinal ganglion cells of the cat, The Journal of Physiology, vol.187, issue.3, pp.517-552, 1966. ,
DOI : 10.1113/jphysiol.1966.sp008107
Spiking Neuron Models, 2002. ,
Eye Smarter than Scientists Believed: Neural Computations in Circuits of the Retina, Neuron, vol.65, issue.2, pp.150-164, 2010. ,
DOI : 10.1016/j.neuron.2009.12.009
Pan-retinal characterization of light responses from ganglion cells in the developing mouse retina. bioRxiv, 2016. ,
Following the ontogeny of retinal waves: pan-retinal recordings of population dynamics in the neonatal mouse, The Journal of Physiology, vol.20, issue.7, pp.5921545-1563, 2014. ,
DOI : 10.1113/jphysiol.2013.262840
Cell Populations of the Retina: The Proctor Lecture, Investigative Opthalmology & Visual Science, vol.52, issue.7, pp.4581-4591, 2011. ,
DOI : 10.1167/iovs.10-7083
Inferring Nonlinear Neuronal Computation Based on Physiologically Plausible Inputs, PLoS Computational Biology, vol.78, issue.7, p.1003143, 2013. ,
DOI : 10.1371/journal.pcbi.1003143.s006
Inferring Nonlinear Neuronal Computation Based on Physiologically Plausible Inputs, PLoS Computational Biology, vol.78, issue.7, p.2013 ,
Proximit?? et dualit?? dans un espace hilbertien, Bulletin de la Société mathématique de France, vol.79, pp.273-299, 1965. ,
DOI : 10.24033/bsmf.1625
Gradient methods for minimizing composite functions, Mathematical Programming, pp.125-161, 2013. ,
DOI : 10.1007/s10107-012-0629-5
A super-resolution approach for receptive fields estimation of neuronal ensembles, BMC Neuroscience, vol.16, issue.Suppl 1, 2015. ,
DOI : 10.1186/1471-2202-16-S1-P130
URL : https://hal.archives-ouvertes.fr/hal-01215541
Maximum likelihood estimation of cascade point-process neural encoding models, Network: Computation in Neural Systems, vol.15, issue.4, pp.243-262, 2004. ,
DOI : 10.1088/0954-898X_15_4_002
Statistical models for neural encoding, decoding, and optimal stimulus design, Prog Brain Res, vol.165, pp.493-507, 2007. ,
DOI : 10.1016/S0079-6123(06)65031-0
Receptive Field Inference with Localized Priors, PLoS Computational Biology, vol.23, issue.10, p.1002219, 2011. ,
DOI : 10.1371/journal.pcbi.1002219.s002
URL : http://doi.org/10.1371/journal.pcbi.1002219
ARock: An Algorithmic Framework for Asynchronous Parallel Coordinate Updates, 35] J. Pillow. Likelihood-based approaches to modeling the neural code. Bayesian brain: Probabilistic approaches to neural coding, pp.53-70, 2007. ,
DOI : 10.1137/15M1024950
URL : http://arxiv.org/abs/1506.02396
Prediction and Decoding of Retinal Ganglion Cell Responses with a Probabilistic Spiking Model, Journal of Neuroscience, vol.25, issue.47, pp.11003-11013, 2005. ,
DOI : 10.1523/JNEUROSCI.3305-05.2005
Spatio-temporal correlations and visual signalling in a complete neuronal population, Nature, vol.22, issue.7207, pp.454995-999, 2008. ,
DOI : 10.1038/nature07140
Variational Analysis, volume 317 of Grundlehren der mathematischen Wissenschaften, 1998. ,
Quantitative analysis of cat retinal ganglion cell response to visual stimuli, Vision Research, vol.5, issue.12, pp.583-601, 1965. ,
DOI : 10.1016/0042-6989(65)90033-7
The Cognitive Neurosciences, 3rd edition, chapter Characterization of neural responses with stochastic stimuli, 2004. ,
A differential equation for modeling nesterov's accelerated gradient method: Theory and insights ,
MODEL COMPLETENESS RESULTS FOR EXPANSIONS OF THE ORDERED FIELD OF REAL NUMBERS BY RESTRICTED PFAFFIAN FUNCTIONS AND THE EXPONENTIAL FUNCTION, Journal of the American Mathematical Society, vol.9, issue.4, pp.1051-1094, 1996. ,
DOI : 10.1142/9789812564894_0029
Model and large-scale simulator of a biological retina with contrast gain control, 2008. ,
Virtual Retina: A biological retina model and simulator, with contrast gain control, Journal of Computational Neuroscience, vol.32, issue.3, pp.219-249, 2009. ,
DOI : 10.1007/s10827-008-0108-4
URL : https://hal.archives-ouvertes.fr/inria-00160716
