Reports
When Amdahl Meets Young/Daly
Abstract : This paper investigates the optimal number of processors to execute a parallel job, whose speedup profile obeys Amdahl's law, on a large-scale platform subject to fail-stop and silent errors. We combine the traditional checkpointing and rollback recovery strategies with verification mechanisms to cope with both error sources. We provide an exact formula to express the execution overhead incurred by a periodic checkpointing pattern of length $T$ and with $P$ processors, and we give first-order approximations for the optimal values $T^{*}$ and $P^{*}$ as a function of the individual processor failure rate $\lambda_{\mathrm{ind}}$. A striking result is that $P^{*}$ is of the order $\lambda_{\mathrm{ind}}^{-1/4}$ when the checkpointing cost grows linearly with the number of processors, and of the order $\lambda_{\mathrm{ind}}^{-1/3}$ when the checkpointing cost stays bounded for any $P$. We conduct an extensive set of simulations to support the theoretical study. The results confirm the accuracy of the first-order approximation under a wide range of parameter settings.
Complete list of metadatas
https://hal.inria.fr/hal-01280004
Contributor : Equipe Roma <>
Submitted on : Sunday, February 28, 2016 - 6:43:25 PM
Last modification on : Friday, April 20, 2018 - 3:44:27 PM
Long-term archiving on: : Sunday, November 13, 2016 - 4:32:07 AM
File
RR-8871.pdf
Identifiers
  • HAL Id : hal-01280004, version 1
Citation
Aurélien Cavelan, Jiafan Li, Yves Robert, Hongyang Sun. When Amdahl Meets Young/Daly. [Research Report] RR-8871, ENS Lyon, CNRS & INRIA. 2016. ⟨hal-01280004v1⟩
Share
Metrics
Record views
37
Files downloads
10
