New interface
Conference papers
Automated Analysis of Asynchronously Communicating Systems
Lakhdar Akroun 1 Gwen Salaün 1 Lina Ye 2, 3
Abstract : Analyzing systems communicating asynchronously via reliable FIFO buffers is an undecidable problem. A typical approach is to check whether the system is bounded, and if not, the corresponding state space can be made finite by limiting the presence of communication cycles in behavioral models or by fixing the buffer size. In this paper, our focus is on systems that are likely to be unbounded and therefore result in infinite systems. We do not want to restrict the system by imposing any arbitrary bound. We introduce a notion of stability and prove that once the system is stable for a specific buffer bound, it remains stable whatever larger bounds are chosen for buffers. This enables one to check certain properties on the system for that bound and to ensure that the system will preserve them whatever larger bounds are used for buffers. We also prove that computing this bound is undecidable but we show how we succeed in computing these bounds for many examples using heuristics and equivalence checking.
Complete list of metadata
Cited literature [41 references]  Display  Hide  Download
https://hal.inria.fr/hal-01280164
Contributor : Radu Mateescu Connect in order to contact the contributor
Submitted on : Monday, May 9, 2016 - 3:52:26 PM
Last modification on : Tuesday, October 25, 2022 - 4:18:02 PM
Long-term archiving on: : Tuesday, November 15, 2016 - 11:50:02 PM
File
Akroun-Salaun-Ye-16.pdf
Identifiers
Citation
Lakhdar Akroun, Gwen Salaün, Lina Ye. Automated Analysis of Asynchronously Communicating Systems. 23rd International SPIN symposium on Model Checking of Software, Apr 2016, Eindhoven, Netherlands. ⟨10.1007/978-3-319-32582-8_1⟩. ⟨hal-01280164⟩
Share
Metrics
Record views
940
Files downloads
158
