Stability Analysis for Impulsive Systems: 2D Vector Lyapunov Function Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2016
Hector Ríos
  • Fonction : Auteur
  • PersonId : 969242
L Hetel
Denis Efimov
This paper contributes to the stability analysis for impulsive dynamical systems based on a vector Lyapunov function and its divergence operator. The new method relies on a 2D time domain representation. The result is illustrated for the exponential stability of linear impulsive systems based on LMIs. The obtained results provide some notions of minimum and maximum dwell-time. Some examples illustrate the feasibility of the proposed approach.
_TechnicalReport.pdf (520.8 Ko) Télécharger le fichier
hal-01280321 , version 1 (29-02-2016)
  • HAL Id : hal-01280321 , version 1
Hector Ríos, L Hetel, Denis Efimov. Stability Analysis for Impulsive Systems: 2D Vector Lyapunov Function Approach. [Research Report] Inria Lille - Nord Europe. 2016. ⟨hal-01280321⟩
177 Consultations
193 Téléchargements
