Entropy production and mesh refinement – Application to wave breaking
We propose an adaptive numerical scheme for hyperbolic conservation laws based on the numerical density
of entropy production (the amount of violation of the theoretical entropy inequality). Thus it is used as an a
posteriori error which provides information on the need to refine the mesh in the regions where
discontinuities occur and to coarsen the mesh in the regions where the solutions remain smooth.
Nevertheless, due to the CFL stability condition the time step is restricted and leads to time consuming
simulations. Therefore, we propose a local time stepping algorithm. This approach is validated in the case of
classical 1D numerical tests. Then, we present a 3D application. Indeed, according to an eulerian bi-fluid
formulation at low Mach, an hyperbolic system of conservation laws allows an easily parallelization and
mesh refinement by “blocks”.
Mécanique [physics.med-ph]
