New interface
Conference papers
fREX: fUML-based Reverse Engineering of Executable Behavior for Software Dynamic Analysis
Abstract : Reverse engineering is still a challenging process, notably because of the growing number, heterogeneity, complexity, and size of software applications. While the analysis of their structural elements has been intensively investigated, there is much less work covering the reverse engineering of their behavioral aspects. To further stimulate research on this topic, we propose fREX as an open framework for reverse engineering of executable behaviors from existing software code bases. fREX currently provides model discovery support for behavior embedded in Java code, employs the OMG's fUML standard language as executable pivot format for dynamic analysis, and uses model transformations to bridge Java and fUML. Thus, fREX also aims at contributing to explore the relationship between programming languages (e.g., Java) and executable mod-eling languages (e.g., fUML). In this paper, we describe the proposed fREX framework and its current reverse engineering support covering some core Java features. In addition we discuss how the framework can be used for performing different kinds of dynamic analysis on existing software, as well as how it could be extended in the future.
Complete list of metadata
Cited literature [26 references]  Display  Hide  Download
https://hal.inria.fr/hal-01280484
Contributor : Hugo Bruneliere Connect in order to contact the contributor
Submitted on : Friday, March 4, 2016 - 10:04:34 AM
Last modification on : Wednesday, April 27, 2022 - 4:43:56 AM
Long-term archiving on: : Sunday, June 5, 2016 - 10:11:02 AM
File
fREX_MiSE-ICSE2016_authors-ver...
Identifiers
Citation
Alexander Bergmayr, Hugo Bruneliere, Jordi Cabot, Jokin Garcia, Tanja Mayerhofer, et al.. fREX: fUML-based Reverse Engineering of Executable Behavior for Software Dynamic Analysis. 8th Workshop on Modelling in Software Engineering (MiSE’2016) - Co-located with ICSE 2016, May 2016, Austin, United States. ⟨10.1145/2896982.2896984⟩. ⟨hal-01280484⟩
Share
Metrics
Record views
550
Files downloads
543
