Abstract : In this paper we present an approach to specify programs performing iterations. The idea is to specify iteration in terms of the nite sequence of the elements enumerated so far, and only those. In particular, we are able to deal with non-deterministic and possibly innite iteration. We show how to cope with the issue of an iteration no longer being consistent with mutable data. We validate our proposal using the deductive verication tool Why3 and two iteration paradigms, namely cursors and higher-order iterators. For each paradigm, we verify several implementations of iterators and client code. This is done in a modular way, i.e., the client code only relies on the specication of the iteration.
