Indirect internal stabilization of weakly coupled evolution equations, Journal of Evolution Equations, vol.2, issue.2, pp.127-150, 2002. ,
DOI : 10.1007/s00028-002-8083-0
A unified approach via convexity for optimal energy decay rates of finite and infinite dimensional vibrating damped systems with applications to semi-discretized vibrating damped systems, Journal of Differential Equations, vol.248, issue.6, pp.248-1473, 2010. ,
DOI : 10.1016/j.jde.2009.12.005
URL : https://hal.archives-ouvertes.fr/hal-00594842
Energy decay for Timoshenko systems of memory type, Journal of Differential Equations, vol.194, issue.1, pp.82-115, 2003. ,
DOI : 10.1016/S0022-0396(03)00185-2
Frictional versus Viscoelastic Damping in a Semilinear Wave Equation, SIAM Journal on Control and Optimization, vol.42, issue.4, pp.1310-1324, 2003. ,
DOI : 10.1137/S0363012902408010
Some remarks on stability of semigroups arising from linear viscoelasticity, Asymptot. Anal, vol.46, pp.251-273, 2006. ,
Asymptotic stability in viscoelasticity, Archive for Rational Mechanics and Analysis, vol.37, issue.4, pp.297-308, 1970. ,
DOI : 10.1007/BF00251609
Quelques résultats de stabilisation indirecte des systèmes couplés non dissipatifs, Bull. Belg. Math. Soc, vol.15, pp.479-497, 2008. ,
Asymptotic stability of abstract dissipative systems with infinite memory, Journal of Mathematical Analysis and Applications, vol.382, issue.2, pp.748-760, 2011. ,
DOI : 10.1016/j.jmaa.2011.04.079
URL : https://hal.archives-ouvertes.fr/hal-01094955
On the control of solutions of a viscoelastic equation, Appl. Math. Comput, vol.206, pp.589-597, 2008. ,
General energy decay estimates of Timoshenko systems with frictional versus viscoelastic damping, Mathematical Methods in the Applied Sciences, vol.206, issue.2, pp.2101-2122, 2009. ,
DOI : 10.1002/mma.1125
URL : https://hal.archives-ouvertes.fr/hal-01094959
On the stabilization for a linear Timoshenko system with infinite history and applications to the coupled Timoshenko-heat systems, Elec. J. Diff. Equa, pp.2012-2013, 2012. ,
Exact Controllability and Stabilization. The Multiplier Method, 1994. ,
Uniform boundary stabilization of semilinear wave equations with nonlinear boundary damping, Differential and Integral Equations, pp.507-533, 1993. ,
Regularity of higher energies of wave equation with nonlinear localized damping and source terms, Nonlinear Analysis: TMA, pp.69-898, 2008. ,
Decay rates for dissipative wave equations, pp.61-75, 1999. ,
General decay of the solution energy in a viscoelastic equation with a nonlinear source, Nonlinear Analysis: Theory, Methods & Applications, vol.69, issue.8, pp.2589-2598, 2008. ,
DOI : 10.1016/j.na.2007.08.035
Uniform decay in a Timoshenko-type system with past history, Journal of Mathematical Analysis and Applications, vol.360, issue.2, pp.459-475, 2009. ,
DOI : 10.1016/j.jmaa.2009.06.064
URL : https://hal.archives-ouvertes.fr/hal-00628724
Stability of Timoshenko systems with past history, Journal of Mathematical Analysis and Applications, vol.339, issue.1, pp.482-502, 2008. ,
DOI : 10.1016/j.jmaa.2007.07.012
Asymptotic stability of semigroups associated with linear weak dissipative systems with memory, Journal of Mathematical Analysis and Applications, vol.326, issue.1, pp.691-707, 2007. ,
DOI : 10.1016/j.jmaa.2006.03.022
General stability result for viscoelastic wave equations, Journal of Mathematical Physics, vol.53, issue.5, p.53702, 2012. ,
DOI : 10.1063/1.4711830
Exponential stability in linear viscoelasticity, Quarterly of Applied Mathematics, vol.64, issue.3, pp.499-513, 2006. ,
DOI : 10.1090/S0033-569X-06-01010-4
Semigroups of linear operators and applications to partial differential equations, 1983. ,
DOI : 10.1007/978-1-4612-5561-1
On the correction for shear of the differential equation for transverse vibrations of prismaticbars, pp.744-746, 1921. ,
