Asymptotic behavior for Timoshenko beams subject to a single nonlinear feedback control, Nonlinear Differential Equations and Applications NoDEA, vol.14, issue.5-6, pp.643-669, 2007. ,
DOI : 10.1007/s00030-007-5033-0
URL : https://hal.archives-ouvertes.fr/hal-00594830
Energy decay for Timoshenko systems of memory type, Journal of Differential Equations, vol.194, issue.1, pp.82-115, 2003. ,
DOI : 10.1016/S0022-0396(03)00185-2
Stability of Timoshenko systems with past history, J. Math. Anal. Appl, vol.339, issue.1, pp.482-502, 2008. ,
On the control of a viscoelastic damped Timoshenko-type system, Applied Mathematics and Computation, vol.206, issue.2, pp.589-597, 2008. ,
DOI : 10.1016/j.amc.2008.05.122
URL : https://hal.archives-ouvertes.fr/hal-01094960
General energy decay estimates of Timoshenko systems with frictional versus viscoelastic damping, Mathematical Methods in the Applied Sciences, vol.206, issue.2, pp.2102-2122, 2009. ,
DOI : 10.1002/mma.1125
URL : https://hal.archives-ouvertes.fr/hal-01094959
Evolution equations in Thermoelasticity, Pitman Monogr, Surveys Pure Appl. Math. Boca Raton, vol.112, 2000. ,
Boundary Control of the Timoshenko Beam, SIAM Journal on Control and Optimization, vol.25, issue.6, pp.1417-1429, 1987. ,
DOI : 10.1137/0325078
Semigroups associated with dissipative systems 398, Research Notes in Mathematics, 1999. ,
On the Internal and Boundary Stabilization of Timoshenko Beams, Nonlinear Differential Equations and Applications NoDEA, vol.15, issue.6, pp.655-671, 2008. ,
DOI : 10.1007/s00030-008-7075-3
On the stabilization of the Timoshenko system by a weak nonlinear dissipation, Mathematical Methods in the Applied Sciences, vol.12, issue.1, pp.454-469, 2009. ,
DOI : 10.1002/mma.1047
A general stability result in a memory-type Timoshenko system, Communications on Pure and Applied Analysis, vol.12, issue.2, pp.457-468, 2009. ,
DOI : 10.3934/cpaa.2013.12.957
Uniform decay in a Timoshenko-type system with past history, Journal of Mathematical Analysis and Applications, vol.360, issue.2, pp.459-475, 2009. ,
DOI : 10.1016/j.jmaa.2009.06.064
URL : https://hal.archives-ouvertes.fr/hal-00628724
Mildly dissipative nonlinear Timoshenko systems???global existence and exponential stability, Journal of Mathematical Analysis and Applications, vol.276, issue.1, pp.248-278, 2002. ,
DOI : 10.1016/S0022-247X(02)00436-5
Global stability for damped Timoshenko systems, Discrete and Continuous Dynamical Systems, pp.1625-1639, 2003. ,
Timoshenko systems with indefinite damping, Journal of Mathematical Analysis and Applications, vol.341, issue.2, pp.1068-1083, 2008. ,
DOI : 10.1016/j.jmaa.2007.11.012
Exponential stability for the Timoshenko system with two weak dampings, Exponential stability for the Timoshenko system with two week dampings, pp.535-541, 2005. ,
DOI : 10.1016/j.aml.2004.03.017
Uniform stabilization for the Timoshenko beam by a locally distributed damping, Electronic Journal of Differential Equations, vol.29, pp.1-14, 2003. ,
