Asymptotic behavior for Timoshenko beams subject to a single nonlinear feedback control, Nonlinear Diff, Equa. Appl, vol.14, pp.643-669, 2007. ,
A general method for proving sharp energy decay rates for memory-dissipative evolution equations, Comptes Rendus Mathematique, vol.347, issue.15-16, pp.347-867, 2009. ,
DOI : 10.1016/j.crma.2009.05.011
Energy decay for Timoshenko systems of memory type, Journal of Differential Equations, vol.194, issue.1, pp.82-115, 2003. ,
DOI : 10.1016/S0022-0396(03)00185-2
Mathematical methods of classical mechanics, 1989. ,
Some remarks on stability of semigroups arising from linear viscoelasticity, Asymptot. Anal, vol.46, pp.251-273, 2006. ,
Asymptotic stability in viscoelasticity, Archive for Rational Mechanics and Analysis, vol.37, issue.4, pp.297-308, 1970. ,
DOI : 10.1007/BF00251609
Decay rates for solutions of a Maxwell system with nonlinear boundary damping, Computational and Applied Mathematics, vol.21, pp.135-165, 2002. ,
On the Stability of Damped Timoshenko Systems: Cattaneo Versus Fourier Law, Archive for Rational Mechanics and Analysis, vol.328, issue.1, pp.221-251, 2009. ,
DOI : 10.1007/s00205-009-0220-2
A Re-Examination of the Basic Postulates of Thermomechanics, Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.432, issue.1885, pp.432-171, 1991. ,
DOI : 10.1098/rspa.1991.0012
ON UNDAMPED HEAT WAVES IN AN ELASTIC SOLID, Journal of Thermal Stresses, vol.15, issue.2, pp.253-264, 1992. ,
DOI : 10.1093/qjmam/37.2.179
Thermoelasticity without energy dissipation, Journal of Elasticity, vol.2, issue.3, pp.31-189, 1993. ,
DOI : 10.1007/BF00044969
Quelques résultats de stabilisation indirecte des systèmessystèmes couplés non dissipatifs, Bull. Belg. Math. Soc, vol.15, pp.479-497, 2008. ,
Asymptotic stability of abstract dissipative systems with infinite memory, Journal of Mathematical Analysis and Applications, vol.382, issue.2, pp.748-760, 2011. ,
DOI : 10.1016/j.jmaa.2011.04.079
URL : https://hal.archives-ouvertes.fr/hal-01094955
On the control of a viscoelastic damped Timoshenko-type system, Applied Mathematics and Computation, vol.206, issue.2, pp.589-597, 2008. ,
DOI : 10.1016/j.amc.2008.05.122
URL : https://hal.archives-ouvertes.fr/hal-01094960
General energy decay estimates of Timoshenko systems with frictional versus viscoelastic damping, Mathematical Methods in the Applied Sciences, vol.206, issue.2, pp.2101-2122, 2009. ,
DOI : 10.1002/mma.1125
URL : https://hal.archives-ouvertes.fr/hal-01094959
On the stabilization of Timoshenko systems with memory and different speeds of wave propagation, Applied Mathematics and Computation, vol.219, issue.17 ,
DOI : 10.1016/j.amc.2013.03.105
URL : https://hal.archives-ouvertes.fr/hal-01094943
Boundary Control of the Timoshenko Beam, SIAM Journal on Control and Optimization, vol.25, issue.6, pp.1417-1429, 1987. ,
DOI : 10.1137/0325078
Exact Controllability and Stabilization. The Multiplier Method, 1994. ,
Uniform boundary stabilization of semilinear wave equations with nonlinear boundary damping, Differential and Integral Equations, pp.507-533, 1993. ,
Exponential stability for a Timoshenko-type system with history, Journal of Mathematical Analysis and Applications, vol.380, issue.1, pp.299-312, 2011. ,
DOI : 10.1016/j.jmaa.2011.02.078
General decay of the solution energy in a viscoelastic equation with a nonlinear source, Nonlinear Analysis: Theory, Methods & Applications, vol.69, issue.8, pp.2589-2598, 2008. ,
DOI : 10.1016/j.na.2007.08.035
General decay for a porous thermoelastic system with memory: The case of equal speeds, Nonlinear Analysis: Theory, Methods & Applications, vol.74, issue.18, pp.74-6895, 2011. ,
DOI : 10.1016/j.na.2011.07.012
Said-Houari; Nonlinear Damped Timoshenko systems with second sound: Global existence and exponential stability, Math. Meth. Appl. Sci, pp.32-505, 2009. ,
On the Internal and Boundary Stabilization of Timoshenko Beams, Nonlinear Differential Equations and Applications NoDEA, vol.15, issue.6, pp.15-655, 2008. ,
DOI : 10.1007/s00030-008-7075-3
On the stabilization of the Timoshenko system by a weak nonlinear dissipation, Mathematical Methods in the Applied Sciences, vol.12, issue.1, pp.454-469, 2009. ,
DOI : 10.1002/mma.1047
A stability result in a memory-type Timoshenko system, Dynamic Systems Appl, pp.457-468, 2009. ,
A general stability result in a memory-type Timoshenko system, Communications on Pure and Applied Analysis, vol.12, issue.2 ,
DOI : 10.3934/cpaa.2013.12.957
Said-Houari; Energy decay in a Timoshenko-type system with history in thermoelasticity of type III, Advanced Diff, Equa, vol.14, pp.375-400, 2009. ,
Uniform decay in a Timoshenko-type system with past history, Journal of Mathematical Analysis and Applications, vol.360, issue.2, pp.459-475, 2009. ,
DOI : 10.1016/j.jmaa.2009.06.064
URL : https://hal.archives-ouvertes.fr/hal-00628724
Stability of Timoshenko systems with past history, Journal of Mathematical Analysis and Applications, vol.339, issue.1, pp.482-502, 2008. ,
DOI : 10.1016/j.jmaa.2007.07.012
Asymptotic stability of semigroups associated with linear weak dissipative systems with memory, Journal of Mathematical Analysis and Applications, vol.326, issue.1, pp.691-707, 2007. ,
DOI : 10.1016/j.jmaa.2006.03.022
Mildly dissipative nonlinear Timoshenko systems???global existence and exponential stability, Journal of Mathematical Analysis and Applications, vol.276, issue.1, pp.248-276, 2002. ,
DOI : 10.1016/S0022-247X(02)00436-5
Global stability for damped Timoshenko systems, Discrete Contin. Dyn. Syst, vol.9, pp.1625-1639, 2003. ,
Timoshenko systems with indefinite damping, Journal of Mathematical Analysis and Applications, vol.341, issue.2, pp.1068-1083, 2008. ,
DOI : 10.1016/j.jmaa.2007.11.012
General energy decay rates for a weakly damped Timoshenko system, Dynamical and Control Systems, pp.211-226, 2010. ,
Exponential stability in linear viscoelasticity, Quarterly of Applied Mathematics, vol.64, issue.3, pp.499-513, 2006. ,
DOI : 10.1090/S0033-569X-06-01010-4
Semigroups of linear operators and applications to partial differential equations, 1983. ,
DOI : 10.1007/978-1-4612-5561-1
Energy decay for Porous-thermo-elasticity systems of memory type, Applicable Analysis, vol.44, issue.4, pp.451-464, 2008. ,
DOI : 10.1137/S0363012902408010
Uniform stabilization for the Timoshenko beam by a locally distributed damping, Electron. J. Differential Equations, pp.29-30, 2003. ,
On the correction for shear of the differential equation for transverse vibrations of prismaticbars, pp.744-746, 1921. ,
Stabilization of Timoshenko Beam by Means of Pointwise Controls, ESAIM: Control, Optimisation and Calculus of Variations, vol.9, pp.579-600, 2003. ,
DOI : 10.1051/cocv:2003028
Boundary stabilization of Timoshenko beam, System Science and Mathematical Sciences, vol.13, pp.376-384, 2000. ,
Nonlinear Boundary Stabilization of Nonuniform Timoshenko Beam, Acta Mathematicae Applicatae Sinica, English Series, vol.13, issue.2, pp.239-246, 2003. ,
DOI : 10.1007/s10255-003-0099-x
