Integer programming formulations for the k-edge-connected 3-hop-constrained network design problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Networks Année : 2016
In this article, we study the k-edge-connected L-hop-constrained network design problem. Given a weighted graph G = (V,E), a set D of pairs of nodes, two integers L ≥ 2 and k ≥ 2, the problem consists in finding a minimum weight subgraph of G containing at least k edge-disjoint paths of length at most L between every pair {s, t } ∈ D. We consider the problem in the case where L = 2, 3 and |D| ≥ 2. We first discuss integer programming formulations introduced in the literature. Then, we introduce new integer programming formulations for the problem that are based on the transformation of the initial undirected graph into directed layered graphs. We present a theoretical comparison of these formulations in terms of LP-bound. Finally, these formulations are tested using CPLEX and compared in a computational study for k = 3, 4, 5.
hal-01281958 , version 1 (03-03-2016)
Ibrahima Diarrassouba, V. Gabrel, A. R. Mahjoub, L. Gouveia, Pierre Pesneau. Integer programming formulations for the k-edge-connected 3-hop-constrained network design problem. Networks, 2016, 67 (2), pp. 148-169. ⟨10.1002/net.21667⟩. ⟨hal-01281958⟩
177 Consultations
0 Téléchargements
