Value-Chain Discovery from Business Process Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Companies model their business processes either for documentation, analysis, re-engineering or automation purposes; usually using normalized business process modeling languages such as EPC or BPMN. Although these models explain how the processes should be performed and by whom, they abstract away their business rationale (i.e. what is offered and why). Business modeling aims to answer the latter and different frameworks have been proposed to express the process in terms of value-chains. Ensuring alignment between both of these views manually is error prone and labor intensive. In this paper, we present a novel approach to derive a value-chain - expressed in REA - from a business process model expressed in BPMN. At the heart of our approach and our main contribution lies a set of nine general business patterns we have defined and classified as structural and behavioral patterns.
978-3-662-45501-2_3_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01281987 , version 1 (03-03-2016)
Paternité
Anis Boubaker, Dhouha Cherif, Abderrahmane Leshob, Hafedh Mili. Value-Chain Discovery from Business Process Models. 7th IFIP Working Conference on The Practice of Enterprise Modeling (PoEM), Nov 2014, Manchester, United Kingdom. pp.26-41, ⟨10.1007/978-3-662-45501-2_3⟩. ⟨hal-01281987⟩
125 Consultations
225 Téléchargements
