New interface
Conference papers
Harnessing clusters of hybrid nodes with a sequential task-based programming model
Abstract : Runtime systems usually abstract a single node. The Sequential Task Flow (STF) model has been proven efficient on shared memory applications. When harnessing cluster of nodes, how should they communicate? By using explicit MPI user calls ? By using a specific paradigm ? Or can we keep the same STF paradigm and almost the same code, and leave the runtime system handle data transfers? We show how such a system has been sucessfully implemented on top of the StarPU runtime.
Complete list of metadata
https://hal.inria.fr/hal-01283949
Contributor : Marc Sergent Connect in order to contact the contributor
Submitted on : Monday, March 7, 2016 - 10:35:13 AM
Last modification on : Friday, November 18, 2022 - 9:27:05 AM
Long-term archiving on: : Sunday, November 13, 2016 - 8:10:42 AM
File
pmaa14.pdf
Identifiers
  • HAL Id : hal-01283949, version 1
Citation
Emmanuel Agullo, Olivier Aumage, Mathieu Faverge, Nathalie Furmento, Florent Pruvost, et al.. Harnessing clusters of hybrid nodes with a sequential task-based programming model. International Workshop on Parallel Matrix Algorithms and Applications (PMAA 2014), Jul 2014, Lugano, Switzerland. ⟨hal-01283949⟩
Share
Metrics
Record views
257
Files downloads
214
