Vectorial approach to coupled non linear Schrödinger systems under non local Cauchy conditions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applicable Analysis Année : 2016
The paper presents a vectorial approach for coupled general nonlinear Schrödinger systems with nonlocal Cauchy conditions. Based on fixed-point principles, the use of matrices with spectral radius less than one, and on basic properties of the Schrödinger solution operator, several existence results are obtained. The essential role of the support of the nonlocal Cauchy condition is emphasized and fully exploited.
Fichier non déposé
hal-01284253 , version 1 (07-03-2016)
Renata Bunoiu, Radu Precup. Vectorial approach to coupled non linear Schrödinger systems under non local Cauchy conditions. Applicable Analysis, 2016, 95 (4), pp.731-747. ⟨10.1080/00036811.2015.1028921⟩. ⟨hal-01284253⟩
35 Consultations
0 Téléchargements
