Optimal “Sporadic” and Systematic Preventive Maintenance Policy for Leased Equipment under Various Operating Conditions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, the considered system corresponds to a specific equipment proposed for leasing. This equipment is leased to several lessees who use it under various working conditions. The aims of this paper consist in determining optimal maintenance plans which minimize maintenance costs. Two maintenance policies are compared : systematic policy (imperfect preventive maintenance actions are performed, with the same effectiveness factor, after each mission) and “sporadic” policy (imperfect preventive maintenance action can be performed after a mission with its optimal effectiveness factor).
978-3-662-44739-0_55_Chapter.pdf (235.59 Ko) Télécharger le fichier
hal-01284363 , version 1 (28-10-2016)
Paternité
Jérémie Schutz. Optimal “Sporadic” and Systematic Preventive Maintenance Policy for Leased Equipment under Various Operating Conditions. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2014, Ajaccio, France. pp.451-458, ⟨10.1007/978-3-662-44739-0_55⟩. ⟨hal-01284363⟩
234 Consultations
187 Téléchargements
