in the upper part of the figure (raw data, histogram and estimated GM density on the left, estimated empirical and GM cdf on the right), a GM with 4 clusters is fitted to some data, and in the lower part a GM with 3 clusters is fitted to the same data, which leads to bad fitting and a high value of, p.26 ,
1000 p-values generated under a GM model, for n = 30 and under 3 possible levels of overlapping of clusters: a uniform distribution is expected for a good calibration of the test (for the QQ-plot, uniformity means being very close to the diagonal line), p.32 ,
Resampling methods for model fitting and model selection, Journal of Biopharmaceutical Statistics, vol.21, pp.1177-1186, 2011. ,
Introduction to Time Series and Forecasting, pp.978-0387953519, 2002. ,
Goodness-of-fit tests when parameters are estimated . Sankhy¯ a : The Indian Journal of, Statistics, vol.66, issue.1, pp.63-74, 2004. ,
Alternative perturbation method for the molecular vibration???rotation problem, International Journal of Quantum Chemistry, vol.93, issue.3, pp.245-264, 2003. ,
DOI : 10.1002/qua.10556
The VMFCI method: A flexible tool for solving the molecular vibration problem, Journal of Computational Chemistry, vol.99, issue.5, pp.627-640, 2006. ,
DOI : 10.1002/jcc.20374
Bootstrap Methods: A Guide for Practitioners and Researchers Wiley series in Probability and Statistics Semi-parametric estimation for conditional independence multivariate finite mixture models, Statistics Surveys, vol.9, pp.1-31, 2007. ,
Bootstrap Methods and their Application, Cambridge Series in Statistical and Probabilistic Mathematics, 1997. ,
DOI : 10.1017/CBO9780511802843
Maximum likelihood from incomplete data via the em algorithm, Journal of the Royal Statistical Society, Series B, vol.39, issue.1, pp.1-38, 1977. ,
Goodness-of-fit techniques, 1986. ,
mclust version 4 for r : Normal mixture modeling for model-based clustering, classification, and density estimation, 2012. ,
A non-parametric method to estimate the number of clusters, Computational Statistics & Data Analysis, vol.73, pp.27-39 ,
DOI : 10.1016/j.csda.2013.11.012
Statistically rigorous java performance evaluation, Proceedings of the Twenty-Second ACM SIGPLAN Conference on OOPSLA, pp.57-76, 2007. ,
DOI : 10.1145/1297105.1297033
The Art of Computer Systems Performance Analysis : Techniques for Experimental Design, Measurement, Simulation, and Modelling, pp.978-978, 1991. ,
An efficient memory operations optimization technique for vector loops on Itanium 2 processors, Concurrency and Computation: Practice and Experience, vol.17, issue.11, pp.1485-1508, 2006. ,
DOI : 10.1002/cpe.1017
Goodness-of-fit testing based on a weighted bootstrap: A fast large-sample alternative to the parametric bootstrap, Canadian Journal of Statistics, vol.43, issue.403, pp.480-500, 2012. ,
DOI : 10.1002/cjs.11135
URL : https://hal.archives-ouvertes.fr/hal-00865050
Measuring Computer Performance: A Practitioner's Guide, pp.978-0521641050, 2000. ,
Improving load/store queues usage in scientific computing, International Conference on Parallel Processing, 2004. ICPP 2004., 2004. ,
DOI : 10.1109/ICPP.2004.1327902
URL : https://hal.archives-ouvertes.fr/inria-00637256
Raced Profiles: Efficient Selection of Competing Compiler Optimizations, Conference on Languages, Compilers , and Tools for Embedded Systems (LCTES '09), 2009. ,
Producing wrong data without doing anything obviously wrong, ASPLOS, 2009. [MP00] Geoffrey MacLachlan and David Peel. Finite Mixture Models. Wiley series in Probability and Statistics, 2000. ,
Study of Variations of Native Program Execution Times on Multi-Core Architectures, 2010 International Conference on Complex, Intelligent and Software Intensive Systems, 2010. ,
DOI : 10.1109/CISIS.2010.96
URL : https://hal.archives-ouvertes.fr/hal-00643731
Goodness-of-fit tests and nonparametric adaptive estimation for spike train analysis, The Journal of Mathematical Neuroscience, vol.4, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00789127
Bootstrap based goodness-of-fit-tests, Metrika, vol.66, issue.1, pp.242-256, 1993. ,
DOI : 10.1007/BF02613687
Comparing Distributions, 2010. ,
Statistical Analysis of Finite Mixture Distributions, 1985. ,
The Speedup-Test University of Versailles Saint-Quentin en Yvelines Research report number HAL-inria-00443839, 2010. ,
The Speedup-Test: A Statistical Methodology for Program Speedup Analysis and Computation. Concurrency and Computation: Practice and Experience, pp.1410-1426, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00764454
Estimating the number of clusters in a data set via the gap statistic, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.63, issue.2, pp.411-423, 2001. ,
DOI : 10.1111/1467-9868.00293
Asymptotic statistics, 2000. ,
